Mystery Clanking Engine Noise 2011 Fit
Hello Everyone!
I have been driving my Fit for about 6 years now. I have had no major issues, the only thing not working is the AC but it has been that way for a couple years now. I try to do the regular maintenance like oil changes. Over the last several months, this clanking engine noise has been getting louder and louder. It is the worst when idling and at low speeds. I usually stop noticing it when I start accelerating. It does not go away after the car has warmed up either. Here is a video of the engine. You can hear it almost immediately in the beginning of the video and then it returns to the normal idling noise. Any thoughts? I'm happy to take it to a mechanic but I would like to go in with some ideas first.
Video here:
Thanks for any help and I will try to answer follow up questions if needed.
Video here:
I've got zero experience with bottom end work so far. One day I hope to have a project that merits such efforts.
Check that oil level.. My first thought, before reading the peer post, is oil starvation. I can't recall my tending to any faults of this sort. Like, did the vehicle sit for an extended period before this start up? Is there a chance of fluid cross-contamination (odd colored residue, foam, on the oil or coolant fill caps)? Have fluids ever been allowed to get significantly low, that is to say, below the minimum line?
Here's a link to a website showing and explaining how engine oil circulates through an engine. Please forgive me if your experiences have already provided you this information.
Flavlus
06-09-2021 06:04 PM
fukenfit
02-03-2021 06:14 PM
Hondafit11
08-31-2020 06:29 AM
