Help needed identifying a noise
@BaySFit Check out this video, brotha! I hope it helps.
https://www.youtube.com/watch?v=_EfLTszAr7w
Also, what you could do, too, is use a rotary tool and one of those flat, circular cutting disc attachments (image below) and grind a thin, flat hole in the head of the screw. This way, you can use a flat-tipped screw driver, and hopefully loosen it up.
Thanks for tips, I appreciate the advice! Hearing that you got the job done with the same tools as me has me feeling hopeful, so I’ll definitely give it another go. I kind of want to try this weekend, but I already bought the new actuator so I might as well wait on that. I’ll be back with more updates!
I buy all OEM parts from Hondapartsnow.com! they have always done right by me, and I think they’re located San Francisco so if you’re in California they ship ridiculously quickly. I’m in the Bay Area so shipping takes literally a day for me. Sometimes items are out of stock or on back order, but they always let you know the situation in a timely manner and typically get the requested items to you in less time then they initially anticipate. Can’t praise them enough!
Hondafit11
08-31-2020 07:47 PM
handas
08-01-2017 01:58 PM
