Speedbooster question
Old 09-26-2020, 07:52 PM
StGemma's Avatar
Ah, that makes sense.
Old 10-09-2020, 06:53 PM
Frenzal's Avatar
Originally Posted by Black3sr
Damn that is cheap. Let us know how they work.
Installed them this afternoon. For what I can tell right now, perform like OEM or a little bit better. The rust protective coating on the rotors will surely be appreciated in the next few years!
Old 10-18-2020, 02:11 AM
StGemma's Avatar
Just an update to one of my original questions, regarding what to do to prevent the brake line from leaking brake fluid for when removing the caliper. Well, I figured it out! I finally worked on my caliper the other day and removed the brake hose from the brake line. I immediately shoved a plastic tubing (I think the tube hole is 3/16") onto the brake line, bent the tube, and used a clamping tool (not sure what that thing is called), which has a good amount of clamping power, to pinch off the tubing, and viola! No more brake fluid leaking out. I later used a zip tie directly above the clamping tool for secondary reinforcement.
I kept the tubing and clamp tool on there for many, many hours (around thirteen hours or so) to work on the calipers and stuff. Worked great! No leaking after I did this.
Old 10-18-2020, 05:40 PM
Frenzal's Avatar
Good idea!
And it's voilą, not viola!
Old 11-04-2020, 05:25 PM
StGemma's Avatar
Regarding the caliper piston, is it OK to spray some fluid film or other anti-rust agent, inside the piston? I just installed this piston about a week ago, and it's already getting rust inside. :|
Also, I would not recommend buying the Dorman dust boot covers from Rockauto.com, because Dormans do not appear to actually be compatible with the 2012 Fit. The Dormans do not stretch out as far as the OEM dust boot covers do, it seems. Maybe I am wrong, though?
When I took off the caliper earlier, the dust boot wasn't even in the grove on the piston. Maybe I just installed the caliper back incorrectly?
Time to find where to buy an oem dust boot. :/
StGemma
08-11-2020 08:42 PM
ddson33
05-31-2020 02:44 PM
gkitf16
05-11-2016 12:54 PM
NewFitGuy09
11-22-2011 07:13 PM
halfmoonclip
05-16-2009 09:46 PM
Quick Reply: Speedbooster question
