Doing a clutch
Things to complain about: Couldn't find anyone to balance 'em as a pair, or at all. Nobody near me had an arbor small enough to mount 'em on.
The springs on the Exedy clutch. Nothing wrong with them that I've noticed, but they're not the spring within a spring set-up that comes stock.
Feel like the throw out bearing I got was from SFK. Check rockauto and follow the hearts.
I felt like the OEM clutch was too aggressive. This one goes a little easier in regards to engaging first. The luk flywheel was about 1lb less if memory serves.
The blind hole bearing puller by .. I think ABN (will check when home) via Amazon set me back a little in funds. There was something dumb about it.. like something should be threaded for disassembly but isn't. Worked swell nonetheless.
Be sure to pick up some High Temp Urea grease from honda. Goes on the slave cylinder ball chingaderas. The gear shift mechanism also required a special lube if memory serves.
My stock clutch wasn't worn out by 80k miles, however its springs were smashed from rough clutch engagements/dumps.
I wouldn't go back to OEM personally. Might try the clutch kit from Spec.. But it was too pricey.
As for MTF, I run Redline with a partial drain at every oil change (15%). It takes a little longer to heat up but makes stuff less knotchy. At your own risk though. Blackstone Labs has been saying that newer transmissions dont take kindly to aftermarket fluids.
Why would you want shifting to be less notchy?
Interesting weight saving on fly wheel. I wonder if it will be noticeable. fitfreak post#985015 states the flywheel maybe somewhere around 17lbs,and rotational/unsprung mass is usually the best place to shave a pound or two. it may rev a little faster.
What was initially intended to be a write-up turned into a cacophony of banging tools and breaking junk.
The Exedy clutch has a narrower pad but still carries the same weight.
I noted the new flywheel at 0.8lbs less. It's a negligible mod to which I'd prefer a fully balanced assembly. But if a flywheel is due, yeah, i think it made a minor difference that fits (despite lack of refinement) in line but behind my small list of other mods. I've been too lazy to prove it if I even can, but that T-Rev knock-off PCV reed valve had a tremendous effect on shifting, making the flywheel feel unencumbered. It was just annoying to plumb the valve in in a fashion that I found to be acceptable (used small diam. copper tubing and burn-in fittings with silver solder and a butane torch), and I'm still hunting for a better air filter for it.
Despite frustration, I still intend to add the T-Rev chingaderas to our other vehicles. just takes a back seat to maintenance.
As for wanting shifting to be less knotchy you made me realize the room for misunderstanding left by my choice of words. The mentioned MTF smooths engagement, doesn't make it less secure. I've also got a weighted shift knob and buddyclub short shifter. I decidedly didn't like having to move into gears with the same amount of force required for an error (like uh, downshifting into first at 25mph). The stuff moves silky smooth and locks in without the sensation of rubbing hard against the sides of channels or scraping teeth. thicker, more protective feeling film on everything.
EDIT: the blind hole bearing puller is by OTC via amazon
Mister Coffee
09-19-2019 07:37 AM
RSXPARTSMANN
03-28-2015 12:50 PM
YeeFit
05-09-2009 09:34 PM
