Engine light on
Engine light on
I got an engine lights on in my 2011 fit sport and while Driving it blink sometimes and the cargoes into limp mode I immediatelyturn I did change the coil packs and the spark plugs maybe 10000 miles Ago got the code reaf at autozone it said it was a cylinder 2 misfire cylinder 2 is the 2nd one from left to right right? I've been reading about a valve adjustment job or something like that Anybody got any information or any idea on how to do it thanks in advance new to the page i
It's possible your spark plug worked itself loose... there have been a few issues (myself included) where the threads around the spark plug get damaged, mostly after maintenance changing the plugs.
For myself, it eventually ended up with me using a re-thread insert to finally fix it. When it initially started after I changed my plugs, the dealership just re-tightened it (I took it to them since the car actually died a few times and started pinging really loudly/badly). Then it came back faster than before... I re-tightened it myself... and it came back even faster! That's when I used the insert.
hondafitty
07-09-2015 08:26 PM
