water pump
No reason to replace it unless there is a problem with it. Is that listed in the manual? Don’t think it’s a service/maintenance item.
its usually replaced with a timing belt job on belt motors but the Fit has a chain.
You're fine to keep going. I'm fairly sure the service interview recommends 150k service but there's more than a few here who've gone over 200k miles before their water pump service. Case in point this guy went over 400k's on his no problem.
You aren't hurting anything by changing it early. It's your car, do as you please but this engine is so over-engineered it's just not necessary.
I replaced the coolant and thermostat on mine after 10 years and 81k miles a month ago. The thermostat that came out looked brand new. Compared to my brother's PT cruiser which has 115k and been through two thermostats.
Thanks for the replies! To GolNat... there is not a single word about the water pump in the owner's manual. Red 05, thanks for the insight. 400K on the original water pump is certainly confidence building! When one googles the subject, there's really not a lot of info out there. General recommendations for replacing water pumps (on any make/model) are broad-brushed and limited.
Thanks again for the replies. I've found a bit of information which clarifies my original post.
I was looking at the maintenance schedule my local dealer (Open Road Honda, Edison, NJ) puts out.
At 110,000 miles it has "replace timing belt, replace water pump." and "replace engine drive belts."
So I'm wondering if that is something the local dealer dreamed up, or is it genuinely recommended by Honda.
Take a look on the forum for water pump failure posts here; I don't recall much.
You do, however, need to address spark plug and valve timing.
Not a bad time to drain and replace fluids if they haven't been addressed recently IMO (e.g. brake fluid, engine coolant, transmission fluid). 100k miles is a good time to get a good mechanic to check over all components on a lift (e.g. brakes, suspension, steering, tyres, etal.).
spin out:
You have to educate yourself a little more about your car. You haven't said what year / configuration you own but if it's a Gen II, you have a chain timing belt connecting the crankshaft to the camshaft, not a belt. The term, "engine drive belt" is a mystery to me. Maybe someone knows what that means but I don't think that there is such a thing.
Personal experience has taught me that the dealer's tech reps don't always know what they're talking about even if their computer system says x, y, and z needs done.
Get a service manual or ask your questions here and we'll try to help.
spin out:
