Door Panel Removal
Old 10-28-2010 | 02:14 AM
phenoyz's Avatar
Door Panel Removal
How do you remove the DOOR panel of front and rear passenger ???
I want to put dynamat inside to reduce noise
2009 Base
thanks
Old 11-01-2010 | 11:25 AM
jcuecker's Avatar
Start by removing the screw inside the door latch. Then remove the outer plastic piece of the arm rest, it should pop off without too much effort. You will find an additional screw to remove. Now just pry off the door panel. Its held in by 8-9 Honda clips. I found its pretty easy to start at the bottom left.
Rear doors are the same procedure.
Old 11-01-2010 | 08:51 PM
phenoyz's Avatar
Thanks been waiting for anybody to chime in on this
got pics for this diy
thanks
phenoyz
10-27-2010 02:38 AM
TWGE08
01-02-2009 03:31 PM
badself
09-22-2008 11:32 PM
HEMI-Fit
11-11-2007 10:58 PM
dbagnulo@gmail.com
08-26-2005 05:31 PM
Quick Reply: Door Panel Removal
