Hitch won't accept bike rack
Here ye Here ye! Read all about it.
We have an update!
Here are the pics.
As you can see, the shaft of my Yakima Bike Rack is longer than both of the other 1/4" shafts that I had laying around. (Please note that it still fit in my Draw Tight hitches installed on previous cars.)
Both the Yakima (in gold) and other 1/4" shaft that actually fits (in black):
Yakima:
Other 1/4" shaft:
Buddy of mine cutting the Yakima with an angle grinder:
End result (it fits fine now).:
I will take a few pics with a bike or two on as well when I get a chance.
Thank you all for the advise. This thread actually kinda fun.
We have an update!
Here are the pics.
Yakima:
Other 1/4" shaft:
Excellent. Just be mindful that you are using a class 2 accessory on a class 1 hitch, and keep the tongue weight within specs, and you are good to go. Should not be a problem with your bike rack, but those steel platform racks that they sell for SUVs are wicked heavy.
Great shot of the 'cutter'_
Hitch riser
I can fit a shorter 1/4" shaft no problem (used for my Everthere cargo carrier).
Here are some pics of it.
That's 75 pounds of cable that loaded it with to see how she drives with it.
Notice the Hitch Riser that I bought for it because the Fit's hitch is so low to the ground.
as it has been stated above, the reason for the indentation is to prevent class 2 products from being used on a class 1 hitch. All class 1 hitches have that indentation. That's why I went with a light weight Kuat and sold my softride carrier.
I PMed you the info pertaining to where I bought my riser. Feel free to let me know if I can help further.
I know this thread is old, but I just thought I'd add my experience to help anyone who has this problem.
I had the same tab problem on my hitch, and my new Yakima bike rack wouldn't fit far enough in to properly attach it. I used a center punch on the tab on the hitch, then drilled it with a small drill bit, then slowly went up in size to almost 3/8" diameter until the tab fell off/disappeared. It worked perfectly.
I figured I'd rather drill out the tab in a $100 hitch than cut up my nice new Yakima rack that cost $350. The Yakima bike rack part was solid 1-1/4" steel, not tubular, so if the tab drilling didn't work, I'd be in for some serious grinding...either a notch to clear the tab, or cut the end off the rack part. Either way, none of those options would be as easy as drilling the tab off the hitch.
Old post but i had the same damn problem trying to use a Yakima "Stick-up" bike rack on my hitch. I ended up dremmeling a small notch on my yakima snout just enough to pass that stopper.
This is the rack i have
