fun with alternator
fun with alternator
At 96,500 miles our 07 Fit definitely has the pulsing lights issue, started a long long time ago. Got one of those "11177" re-manufactured units that are everywhere. Not only did it whine (bad bearing I guess) but the car was flickering the battery warning light, however the lights didn't pulse. My digital multimeter couldn't see a problem, but I did note the replacement was running 0.3-0.4 volts lower than the original. What a messed up Saturday. So I wrenched it out and put the original back in, which works fine no battery light on the dash, just the lights pulse again.
Did you guys use the $360 Honda OEM, or did I just get a lemon remanuf unit?
Aftermarket starters and alternators are always a crapshoot.
If you have a reputable auto electric rebuilder in your area, you might look into having the original alternator rebuilt....but not if they are going to use the cheapest parts to do it.
I put a Honda reman alt on an 07 (@270k miles) for a customer about a month ago, theirs was pulsing the lights too...my voltmeter was too slow to see it unless I set it on min/max capture.
That car was totaled last week, I should have asked if I can get the alt I installed....so I can put it on my GFs Fit before hers craps out LOL
I replaced the OEM Mitsubishi alternator with a Denso unit from Rock Auto, no issues. It was $45 more but I've had good luck with that brand in other makes.
I second the idea of having the original unit rebuilt at a shop. It takes a day to do, but if you have the time it's the way to go.
I saw that Denso on Amazon, but the $322 price is higher than OEM from the popular online Honda parts stores ($310-$315), but maybe that's a brand new Denso, not a reman. How hard/easy is it to get the $35 core back to Rock Auto for refund credit? Ah, probably not worth the shipping cost, that's on me not them. I guess I'll roll the dice one more time and hope for the best. I'm a pro at changing the alternator now though, lol. Unfortunately having the car down on a weekday is pretty impossible for a local alternator rebuild. I guess I should have left the junk one in for a week and dropped mine off at the shop, too late now, I returned it already.
No issue with core charges on Rock Auto...in fact on a different car, they gave me the core credit on an alternator that I had purchased over a YEAR previous. I did call them first, so as not to waste the shipping $$.
Thanks, will probably try RockAuto/Denso on the next attempt. WHY is the regulator not external to the alternator ... imagine if Apple made cars, you'd have to buy a new car to change the battery.
That seems so 1960's. Who uses external regulators these days?
You should check out some of the much newer Hondas... The alternator on a 2015 Fit has become part of a communication network, the single small wire in the back of the alternator now carries data.....and aftermarket already seems to have one hell of a time getting that to work right.
I can't wait to see what the future brings for the discount parts situation.
