Synchronizer / Gear set (3-4) fitment
Old 04-06-2015 | 10:42 PM
timdog's Avatar
I was looking for 23623-PLW-315 - Sleeve set, Synchronizer (3-4). It seems Honda no longer produces this part. I thought I had a suitable replacement with 23623-P21-315 but it is too big (to fit on a bigger shaft).
So now I have come across 23444-PLW-325 which seems to be the same set but it includes the the third gear.
Can someone tell me if 23444-PLW-325 and 23623-PLW-315 are the same?
Here is a list of measurements I took using my vernier in inches (expect variances of 0.05 or so):
Synchronizer gear: Inner diameter - 2.095inch. Outer diameter - 2.741inch.
Sliding gear (moved by the forks): Inner diameter - 2.640inch. Outer diameter - 3.225inch.
Fixed gear (inside the sliding gear): Inner diameter - 1.179inch. Outer diameter - 2.727inch.
If anyone is able to please measure up the Synchronizer gear at least for me that would be greatly appreciated.
Hope someone out there is technical with Manual Transmissions.
Thanks.
Stoli124
08-01-2023 07:33 AM
tonyd3773
07-06-2008 11:57 AM
tonyd3773
06-21-2008 03:51 PM
tonyd3773
06-20-2008 05:33 PM
tonyd3773
04-26-2008 07:36 PM
