Sensor testing
They can be tested, at least in theory. Exactly how to do so, and what specialized equipment might be needed, and whether you'd have to remove the part from the engine, all vary with different sensors. Not all the sensors are important for the engine being able to start, either.
What exactly happens when you go to start it? If the engine doesn't even crank, it's not a sensor issue; it's a starter motor or associated circuitry problem.
If it does crank, what does the little key light on the instrument panel do? If it's staying on or flashing repeatedly, the immobilizer is preventing the engine from starting. It should just flash on briefly. (I think the '07s have an immobilizer system; but if I'm wrong, please ignore this paragraph.)
usert_l
12-29-2018 02:25 PM
gtv105
06-09-2009 03:21 AM
mmdir2002@yahoo.co.uk
05-04-2005 11:16 AM
nospam_alan@yahoo.co.uk
05-04-2005 11:16 AM
