2007 Fit Engine Stutter -AC issue
Hi- Back again.
I had posted a few weeks back about headlight/dome light flickering and a engine stutter issue.
Flickering issue resolved-had my alternator rebuilt-the voltage regulator was fried.Honda wanted $861.00 for a new alternator-part only- not installed.
I got the work done through a friend at a small shop- rebuilt -all new quality internals-$200
Thought the stumbling/stutter at idle was resolved and noticed the AC switch was off. As soon as I pressed it-the electric fan on the rad engaged and the idle faltered- shut it off and smooth as silk- Touch the AC button and immediately the engine feels like it is missing.
So- Is this electrical? Or is my pump clutch dragging/seizing when it engages?
How can I be sure what the issue is?
You have a coil pack, spark plug, or valve lash clearance adjustment problem. Or, a combination thereof. Turning the AC on only masks the problem. I had similar problems. Search for hesitation, stutter, missing and you'll find hordes of information about it. Personally, if your plugs aren't fried, are gray looking and not broken, then I think it's coil packs. Replace em all.
Changed the plugs back in late July and the issue improved for a few weeks.
But is getting more pronounced now.
So I will change the coil packs.Is there a recommended aftermarket brand?
Honda here wants $119 each and I am hoping to do better than that.
I have resisted changing the coil packs simply because a friend told me that a bad coil would show itself by engaging my Check- Engine Light. It has not. Is he wrong?
I am still baffled by being able to reproduce the stutter /miss at will by turning on the AC.Is it because of the additional electrical load when both electric rad fans cycle when the AC is actuated?
https://www.rockauto.com/catalog/x,c...,parttype,7060
I bought the Hitachi ones but I have had good experiences with the Denso brand in the past.
Thanks.
techman41973@yahoo.com
06-10-2005 06:34 PM
