Shake at idle.
Old 08-26-2013 | 03:02 PM
junior40er's Avatar
Shake at idle.
Can someone tell me if there is a way to narrow down the problem? It shows no CEL at the moment. I do remember headlights "pulsating" at idle in the past but wife changed bulbs and dont know if still present (im deployed so cant check).
Things I suspect:
1) Coil Packs (no cell showing)
2) Alternator (maybe regulator is going bad and affecting idle and I think that sits inside alternator)
3)Valve adjustment
Car has 185K miles and automatic.
Old 08-26-2013 | 03:59 PM
Subie's Avatar
Maybe just a loose or leak in your vacuum lines somewhere if this is just happening on idle.
Not an expert, just some thoughts and virtual troubleshooting:
(1) going bad I would think would cause misfire or hesitation when accelerating.
(2) going bad would affect your lights and so would a battery or charging system going bad. Don't think it would cause rough idle though.
(1) and/or (3) would affect more than just your idle and eventually light up your CEL I would think.
Hopefully the experts here will chime in...
Old 08-27-2013 | 04:24 AM
loudbang's Avatar
With that many miles and if they haven't been changed prior to this I would start with the plugs, then coilpacks, for sure valve adjustment if we are talking about engine shake not lights dimming.
Thanks for your service lets us know if we can help out.
shawnshank
02-15-2016 09:29 AM
canbac21
01-18-2016 05:50 PM
UnicycleWheelie
03-08-2014 11:28 PM
fitomatic
08-23-2013 03:47 AM
ReeSpeed
06-20-2012 04:20 PM
Quick Reply: Shake at idle.
