Will these fit the front of a gd?
looking at new front rotors for my gd, (oem is 240) these are 239mm 4 bolt, these look right on the money? Thoughts?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180611846779&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en
It will bolt onto your front hub, but most likely the hub of the rotor is different, causing fitment issues with your front caliper.
Like above, I recommend getting the correct rotors for your car. Ebay, local partsstores, and online shops will all have the correct parts. Get at least a step above the cheapest. The cheapest rotors usually warp or wear faster. Its worth spending 50+ on the front pair
If you can find a photo of the front discs you will see there is only 3/8s or 1/2 inch where the hub part extends from the rotor itself. But if you look at that rear rotor you can see it sticks out a couple of inches at least. They are not even close.
Doesn't this site offer fronts if they are selling rears?
Vash
12-04-2017 07:24 AM
p1driftfiend
14
12-07-2008 10:51 AM
