AC high pressure switch
ok, here is a story bought an 08 fit a few months ago thought i got good deal due to a history of the car but doesn't apear so : (
was told it just needs a condenser to get ac working, after taking stuff apart found that it also needs a high pressure line with a pressure switch and also a plug which plugs into a pressre switch is missing (cut off) just 3 wires are sticking out, i was able to find a matching plug from a civic which only comes with 2 wires, after checking the wires with a volt meter i was able to reconnect 2 wires and had my clutch engaged and the fans were working, but i have no idea where the third wire goes, also i noticed that for some reason my fans kicked in after the car was turned off, and this moment i'm doomed, i disconnected the plug from the pressure switch, and was searching online for a wiring the diagram but had no luck, except finding this cool forum with lots of helpful information, if there are anyone who can give me any information i will really be thankful, thank you
Dennis
Dennis
found this link with a diagram Wiring Diagram
looks like it i can solve my issue now
there are more wiring diagrams, and other helpful stuff
sschoe2@gmail.com
07-03-2017 08:13 PM
bobby0600
09-11-2015 06:52 PM
buttersandpaper
10-21-2012 02:03 AM
