Jdm cluster into us fit
Anyone has any info on this or all we need is the jdm cluster diagram am sure just some wires have to be chaged around,
i just bought a cluster 2004 fit from japan for $230us was so excited and when i plugged it in only park lights work
Im sure it will work. But if you have the cruise control on the steering wheel. You will loose the function until you have it re-coded to the new cluster or if there is anyone way around getting it coded again please lmk
Just wanted to say I got my JDM Cluster for $40 from Yahoo auctions.
Also, I am having the same issues.
-Speedo works
-Tachometer doesn't work
-Fuel Gauge doesn't work
-EPS Stays On
Any input or suggestions would be greatly appreciated!
P.S. I have an M/T Fit, so the tacho might not work because of that.
Sorry for the low quality pics.
-Speedo works
-EPS Stays On
I did a little digging and found out that re-wiring needs to be done on the plugs in order for everything to work. If anyone's got a diagram for the jdm/usdm, it will be greatly appreciated!
I read they have the same issues on the GE. You need to find the wiring diagram for the USDM GE and JDM GE, and re-wire the plugs.
devmail
09-14-2022 02:37 AM
