transmission question
i have 08 fit sport MT..and i noticed that coming from stop 1st gear engaged and i accelerates and stay at certain rpm like between 2,500 to 3k..acceleration sound change ike some rotating thing and its noticeable since the sound changes...more likely gear sound bout not grinding sound...happens on 2nd gear also..but after driving a while it goes away..any help?
Maybe you can just put all your questions about sounds from the car into one thread, instead of making a new thread for every sound you notice.
This could just be a heat shield if you're hearing the same resonant sound around the same RPM no matter what the gear. You'd hear it at the same RPM, even in neutral if it's a heat shield.
sorry bout that just trying to figure out what the sound really is. im confused, can't really categorize it from where it is supposed to be. thank you for the suggestion tho...ill try to check my heat shield at the same time im still trying to analize where the sound really coming from..just to add when car is parked and rev the engine theres no such sound like a describe...and i have no problem shifting or niether driving the car...
another update i listened to it carefully..and i searched on others forums, sound is like when im on 1st gear and rpm going up sound changed like similar to the sound of reverse?..any other idea?
jdubau55
04-16-2013 03:14 PM
Santiad
11-05-2011 10:18 PM
BraytonAK
07-24-2010 02:40 PM
