Rear Strut Help
Old 02-04-2013 | 08:31 PM
xizorian's Avatar
Rear Strut Help
T1R Carbon Fiber Rear Strut Bar....I am trying to remove the screw on top of the strut using an allen wrench in the screw thread and a 14mm wrench. Neiher one will budge. I even connected my hydraulic jack handle to the end of the allen wrench for leverage and nothing. Bent the damn jack handle. Whole thing spins or nothing moves. Any ideas?
Is this threaded the opposite way? I don't think an impact wrench will help because you have to hold the allen wrench on top of the screw and can not get a socket on it. Thanks in advance for any ideas to help. Thanks!
Old 02-04-2013 | 10:57 PM
doctordoom's Avatar
Supervillain
Have you tried any penetrating lubricants like WD40 or pb blaster?
Old 02-05-2013 | 01:11 PM
Wafulz's Avatar
+1 rep doctordoom WD40 best friend
mines were hard ass shit too i got a 2012
Old 02-05-2013 | 02:08 PM
gimme's Avatar
Administrator
pb blast is the only thing I use.
Old 02-26-2013 | 11:01 AM
nekret's Avatar
In a pinch I've had some good luck with the poor mans impact: setup your allen and wrench as normal, preload your wrench by pushing on it and then take a heavy (3-5 pound) steal mallet and hitting the end of the wrench. Don't be afraid to hit it hard as it may take a few whacks to get it free. Another option would be a breaker bar and a crows foot wrench set:
Amazon.com: Professional-Grade 15-Piece Crowfoot Wrench Set - METRIC: Home Improvement Amazon.com: Professional-Grade 15-Piece Crowfoot Wrench Set - METRIC: Home Improvement
As already mentioned, hit that sucker with some penetrating oil first and give it a minimum of 10 minutes to soak in.
hialoooha
08-18-2014 11:20 PM
fillit
05-17-2011 04:00 AM
ciref8
05-11-2011 02:51 PM
BlazeOrangeFitTuner
01-12-2008 05:53 PM
MNfit
13
01-01-2008 04:41 PM
Quick Reply: Rear Strut Help
