08 honda fit sport transmission issues
hi i have been to a bunch of threads but this thing hasnt been talked about so i am opening this thread.have googled but nothing came up for honda fits buthave a similar problem with a different car.
"ok car is a 95 integra LS automatic. When I'm at a stop light, with my foot on the brakes, the car jerks as if I'm giving it gas, then lets off. Has this happened to anybody? It does this too when I'm driving at low rpms. I am clueless as to what this could be...electrical, tranny, etc. I have no check engine light either. Any help would be deeply appreciated. "
i have the exact problem as this guy and im not too sure if its normal for a fit.i have 93k miles on my car.would appreciate an answer asap so i can bring my car back to the dealer which i bought 2 weeks ago..thanks!
Vehicle idle circuit needs to be checked as well as air intake system, both air filter and MAF circuit.
Spark plugs and coil packs toio.
so its not the transmission thats messed up?i think they already changed the air filter the spark plugs since they do tune ups before they sell the car.
found a thread with the same problem but for GE's but no answer?
https://www.fitfreak.net/forums/2nd-...tml#post925993
https://www.fitfreak.net/forums/2nd-...king-stop.html
so is this just normal?
The description is too vague to diagnose via the internet -- could be any number of things from complex and expensive to easy and cheap, or it could be something normal that you're not used to (A/C cycling?). Knowing the car's prior history would be helpful. As a first step, I'd simply take it back and have the dealer look into it.
Lastly, just FYI, Fits have a MAP, manifold pressure sensor, not a MAF, mass airflow sensor. The PCU uses the MAP sensor along with a temperature and engine rpm to determine incoming air density. A MAF uses a MAP, temperature, and measured air flow through the MAF to determine air density. The latter is more accurate but more expensive to put in cars.
