Battery or Starter
going to test it after charging anyway not ksa is (south africa)....
Oops sorry...
That boiling sound is electrolysis, converting water to hydrogen and oxygen. It is also creating heat. Hopefully you removed the cell covers from the battery. Replace your battery. Batteries that don't hold a charge need to be replaced. Hence, your battery.
Yes I get that... But the boiling sound shouldn't be that prominent as I perceive EXT as describing. Could be bone dry now... Either way yes, I would be looking for a new battery if it was me.
Sure you hooked it up correctly.?
Boiling isn't normal ans is one indication of current the wrong way. Your battery charger should have a current meter; as soon as current draw is less than 2 amps you should be able to start your engine.
Its asnother reassdon to get another battery.
after charging car is starting fine. i filled distill water to top up before charging and checked the water level all seems fine. current meter showed 0 amp while charging. will see how how the things goes.............
ok finally this Yuasa battery died on me. no matter what i do it doesn't keep charge. so after few months of using it really dead....
got a new battery from HONDA dealer thats surprise me its YUASA ,MADE IN CHINA ( no more JAPAN (
#32
we haven't replaced a Fit battery in over a year so I can't say for sure but I believe one of the major battery manufacturers now offers one for the Fit,. possibly Interstate.
Good luck.
pzriddle
01-23-2015 06:31 PM
piclistguy@yahoo.com
05-04-2005 11:16 AM
