Cylinder Head needs to be rebuilt
Okay, just helping out my brother here. First off, he's a horrible driver (doesn't listen to his car when it needs fixing) and he has a 2009 Honda Fit base model. It was sent to a relative who owns an auto-shop and he (my uncle) said that the compression ranges from 0-50psi and the valves are bent etc; etc;. The fit was bought in a bank auction or $6,000 and the previous owner did not service it at all since 2009 (had over 90,000 miles on it too) It was in rough condition, but when we got it it had a good tune-up and my mother then gave it to my brother.
My uncle said in total, the job may cost ~$3,000 to repair the engine and what-not (and replacement parts from Honda Dealer) Any recommendations? Can I just buy a new cylinder head for under $500 shipped?
You might be able to buy JCrimson's engine and ECU if he has yet to have sold it... Check out wrecking yards for an used engine also if he or someone else here doesn't have one for sell.
So if the valves are bent... check and replace the timing components, polish the piston tops, get new valves, diamond paste them and reseat them, check the new installed height adjust the lash and let her rip
Why on earth would that cost $3k?
I dunno I think that would be a pretty common quote! Or at the very least, an initial quote would be close to that. It may not be that much work but, crucially, it's more work than most people can do on their own ... therefore the price to pay someone is a lot higher than, say, brake replacement where there is an alternative (ie do it yourself). It probably doesn't cost nearly that much for the shop to do it but that's what they'll ask. Could be wrong, of course
So the only symptom was that it wouldn't start? You guys already checked the common culprits like the battery, alternator, and starter right?
Any shop can check your battery and alternator for you. Just make sure it's not a cheap to fix before jumping into something bigger, even if it is family that's saying you need a major repair.
Not sure I'd sink $3K into an engine that was so thoroughly abused by the PO. I think I'd be searching salvage yards, which I know would be a gamble, but if the wreck looked like it had been well maintained and if the engine compression is OK.
P.S. Just checked eBay. There's a 34K mile complete engine from an '09 for $750 including a warranty of sorts.
Since the engine that is presently in the car was never maintained properly a decently maintained engine from a wrecked car would be the best option.... If it was only bent valves you had to deal with, what DSM suggested would be the best route to take, but it sounds like the engine you have is going to be a PITA due to 90,000 miles of neglect.
The labor would cost a lot because my uncle doesn't have machines to do the necessary adjustments to the head and our OEM dealer here is horribly expensive.
Locally, that'd be hard. Haven't seen or heard of any Fit down and where I live is pretty darn small.
http://www.ebay.com/itm/09-10-HONDA-...ht_4175wt_1063
That one huh?
CelestialBlue
08-13-2012 12:30 PM
damooster
11-23-2009 09:19 AM
Rocky
07-16-2005 11:13 PM
