Changing Automatic Transmission Fluid / Anti-Freeze
I have a 2007 Honda Fit Sport and it has about 99,000 miles on it. I had a service done at the dealership at about 69,000 miles and today the guy told me I need to change the transmission fluid again (at every 30,000 miles). It has an automatice transmission. This seems ok to me, and there is many articles on the web agreeing with this, but I wanted to know a few things about this as a I want to start doing it myself:
1. Should I use Honda's fluid or is it safe to use another? How much does it take?
2. I read that to keep the transmission in good shape I should drain, fill, drive 100 miles, drain & fill again, drive another 100 miles and do it one last time. Should I do this? I don't mind if it'll keep the transmission going well.
3. How hard is this to do? Any tips as to were the drain plug and fill location are?
And, on another note, I thought I'd change to coolant (anti-freeze). Should I get a Prestone kit to flush / fill and use a 50/50 mixture? What are your thoughts?
Look forward to your guidance!
You can't go wrong with Honda fluids. They are often a bit different in formulation than other brands.
So, for the transmission, have 4 qts on hand, and a crush washer to re-seal the drain bolt. Honda DW-1 fluid. You will use a little over 3 quarts. If you are not having any shifting issues, a single drain is all you need. If you ARE having problems, a 3X drain as you describe will replace 95% of the fluid.
Honda Blue coolant is said to last 5 years or 120K miles. You could let it go another year if you want. It is only available in a 50/50 mix. You don't need the old flush-n-fill kits anymore (because, like the tranny fluid, you will replace a percentage of the coolant, but then repeat the procedure every three years or so from now on, to keep it "fresh").
It's about time you replaced your brake fluid, isn't it? Honda recommends every 3 years regardless of miles. You will need about 2 bottles to do a complete fluid replacement.
How do I change brake fluid?
I saw the Honda blue coolant at the Honda dealer so I'll pick some up on Monday.
And, if possible, can you tell me how hard it is to change the brake fluid? I should probably do that as well.
I appreciate your help!!!
There are different ways of doing it, and folks will tell you which works best for them.
Rather than me typing all the scenarios and different methods, I'd look on YouTube for videos (all cars are similar) or on Forums for detailed procedures. Then get back to us here with any questions.
naMtiF
09-28-2013 05:59 PM
omygod711
05-24-2010 07:15 PM
