Rubber window trims sticking to window
I recently had a problem with my Rubber trims sticking to my windows , causing the rubber trim to wedge.
I would just like to share the best solution, which I surprised and found it very practical.
Of course nothing beats silicone spray, but this one again is very practical and economical.
From my research I found out that Talcum powder will do the job. Glass slides best on rubber when treated with talcum powder. I also found out that the rubber trims work best when they are clean and dry.
Hope this will help you guys
I had this problem last summer, so bad that my drivers window wouldn't roll back up without some physical assistance by me pushing it up.
Do not use silicone spray/lubricant! I did and it caused the rubber to begin to crack and slowly disintegrated.
Honda replaced the rubber window track under warranty for me. So far no problems!
Hello
I have the same problem. I bought my 07 Fit in may 2011 and previous owner had front windows tinted. In february 2012 I went on MOT and dude there sad that is prohibited in Slovenia to have front windows tinted and I had to pull down the gray foil. Of course, mounting adhesive stayed on and the windows are all sticky when is hot outside.
I found that nail polish remover will clean off the adhesive.
The problem is how to get under (behind) the rubber trims at the bottom of the window, can I remove the rubber trims somehow.
I pulled them up, but I was afraid to brake something if I pulled to much.
I searched the internet but I didn't know if this (rubber trim) is the right name of the thing. I didn't find anything useful.
Can anyone offer some solution to properly remove the strip of rubber at the bottom of front driver`s window?
This is how it looks:
This black strip of plastic/rubber I want removed:
Thanks for helping me.
_________________________________
Addition:
I had to take off the door panels to clean sticky adhesive. Now is everything perfect.
If anyone is going to need this information....
Addition:
As mentioned above, this is what Honda uses to lubricate rubber door trim and sunroof seals.
It only takes a very small amount and you rub it in with your fingers. I have been using this tube since I bought it for the sunroof seals on my '99 EPB Honda Civic Si.
patm95
06-22-2016 11:36 AM
