15x8.5 +15 .. question
P1012611.jpg?t=1305746300
.. plus I guess it helps to run a smaer tire. what size tires are you guys using? I'm poor so I'm reusing the tires I had on my previous wheels. I'm on the 195/50/15 ones. can u guys suggest what tire size I could run? pls n ty. =]
#36
would it be safe to dremel off that little lip instead of rolling fenders? (referring to the rear)
does the rear camber kit adjust? if so how far can it go?
I actually tried to ghetto roll it by using a bat. unfortunately it still rubs. I think it's on that tab where the fender meets the bumper. =[ I thought maybe I could just get away with maybe a slight adjustment on the camber. you think it may work?
btw, thank you fellas for helping this grl out.
#38
#39
can it adjust a lot? or give minor negative camber?
was it easy to throw on?
#40
on the front bolts it depends on witch ones you get cause some are 2 degrees + or - and theres others that do 4 degrees + or - and those are easy to install and for the rear you can do as much camber as you would like but with the m camber you might need to get longer bolts..
