When To Change The Serpentine Belt
#61
I am interested in serpentine belt tension adjustment for a 2007 sport fit. The honda tool is over $200.00. I am not interested in that. I searched for a generic brand and only found adjusters for timing belts. I am almost ready to just eyeball it. Adjustment for a new belt would be not more then a 1/4 inch. The manual says new belts to apply 22 1b f between crank pulley and A/C, the flexion should measure 0.14inc tp 0.20 in on the honda tool # 07JGG-0010100 Does anyone have good sugestions? I do not want to have bad barrings because of too tight of a belt. thank you
#62
At this time it is a great idea to replace idler pulley (its bearing has a HUGE radial play after 60,000 miles).
I rejected two before buying, and I still needed to shim the one I finally bought. The pulley rubbed on the arm because of excessive end-play.
#63
Until car is over 15 years old I stick with OEM (this is why I am driving budget cars, except my 79 Supra but this was a different story
The rule is if OEM part is bad, the aftermarket will be worse!
Have seen this with aftermarket wheel bearings (this is why I am only doing a swap for good used steering knuckle assembly, especially if car saw better days in the past)
mikejet
09-22-2021 11:04 PM
grommet
07-27-2021 09:20 AM
hazzard
11-20-2013 01:38 AM
