Master clutch fail
Master clutch fail
Today i was driving my 07 MR FIT, suddenly went to changer gears.... little to no pedal for the clutch. couldnt changer gears, i started to pump the clutch and i could take it out of gear and off the freeway, i check for a bad slave... nothing yet, fluid is normal level no leaks, no damage to anything. drive-train is stock anyway. at 15k i had the clutch fluid changed by Honda... Im at 35k now (after 3yrs). clutch may be worn... but it feels like the master cylinder... anyone have this problem yet? Im taking the car into the dealership tomorrow for "extended warranty coverage" or at least what i may have waited my money on when i purchased my car.
It could be from an accumulation of moisture in the fluid... The warmer temperatures and driving in traffic where you are stopping and starting a lot could be heating up the fluid in the slave cylinder and causing the water to become steam that is compressing when you push the pedal down and expanding enough when the pedal is out to cause the clutch to slip... I noticed my clutch slipping some yesterday and it seems to not be fully disengaging at times when I am down shifting so I know I'll be purging the system and replacing fluid very soon... I need to do the brakes too.. I'm at 37,750 miles.
Its possible too that the slave cylinder mouinting has loosened or otherwise mismounted so the slave piston arm doesn't line up with the clutch arm (called the fork arm) as its only a pushrod not fastened to the arm.One of my guys says the piston seal isn't replaceable but requires a new master cylinder. Figures. In other words, don't know if the cylinders themselves are rebuidable.
PS we aren't talking about the honda designated master cylinder seal, which is only a gasket. Nor are we talking about the Orings on connections but on the seal on the piston pushrod.
