Need to add positive camber
Old 05-11-2011 | 12:54 AM
thewatcher101's Avatar
The car was in an accident before so the rear camber is off and it has been eating tires because of it. There is too much negative camber.
I am deciding to use either SPEC kit or washers from the hardware store and I want some help deciding which one.
I think the Spec kit is just plastic vs washers from the hardware store that are metal. I think I can either use the spec kit or washers and mount them onto the top two bolts creating positive camber.
It would seem washers are a bit safer as I won't be adding any to the lower half so it will sit closer.
I know all the precautions of using washers and shims.
I am not too worried about getting it perfect just to get good tire wear back. The car is a DD workhorse.
Old 05-11-2011 | 02:11 AM
vtecfit1's Avatar
sucks they didn't fix it right, i'd take it back and make them fix it (assuming you were the one that had it fixed the first time) but a good alignment shop will do it right - remember if you have enough money to do it wrong twice , you have enough to do it right the first time! - just sayin
FitMinister
02-12-2017 02:11 PM
majik808
09-09-2015 10:07 PM
Green karma
19
01-08-2013 12:53 PM
Santiad
08-31-2011 11:18 AM
Jazz GD3
07-11-2009 04:07 PM
