Blown speakers
Blown speakers
Much to my dismay, the front left speakers of my Fit DX just blew. The volume is now lower than normal and it makes a staticky sound. I was informed by my dealer that it is no longer under warranty (passed the 3yr/60,000 km mark). So, I want to replace both front speakers with aftermarket speakers, hopefully with better sound quality (same 6.5 inch size). I need some advice! Does the existing Honda Fit factory deck have enough power to support an upgrade in speakers (or would you recommend changing the deck as well?). I'd prefer not to change the deck if possible... I just want better sound quality. (Note: I have the 2007 Canadian Fit DX, which is the base model that only comes with 2 speakers in the front doors.)
My GD1 also has stock speakers on just the front doors. Trust me, you really don't need them at the back.
The stock HU should work fine, but you won't reap the full benefit of your aftermarket speakers unless you get at least an amplifier. Even aftermarket HUs don't supply all that much wattage per channel. (Of course the big problem with our cars is where exactly to mount an amp and save as much space as possible...)
Good brands? I'd recommend Alpine, Polk Audio, Hertz, Focal. Better if you can "audition" each brand and see how you like their sound as no two pairs of ears are the same. What sounds good for me might not apply to you.
Good luck
Good luck
andryuxa1985
08-07-2019 02:02 PM
Tom Spahr
09-22-2015 08:30 AM
