Offset
You'll rub. I'm on a +32 offset. You'll need a major fender roll with a pull. 20mm spacer (adapter type) wont need extended studs. I suggest buying a 15mm spacer. It will save you some trouble and it will still rub, just not as hardcore.
This is the type of spacer you buy
WHEEL SPACER 15MM HONDA CRX 4X100 12X1.5: eBay Motors (item 150442443759 end time Jul-09-10 10:27:08 PDT)
Yeah I ordered the silver ones n it's coming at the end of July. Thinking about powdercoating it a different color though. haven't decided which color yet, but definately going to need wheel spacers.
I would suggest a 10mm. You shouldn't need new studs and +42 should bring the wheel very close to the fender with little to no rubbing.
I have been thinking of getting those spoons as wheel, jsut really wish they made a 16"
Yep, there was a thread about this in the ajr forums
https://www.fitfreak.net/forums/aj-r...93-wheels.html
10 mm is for minimal work to your fenders or none at all. But yea, I'd still get a 15 for the more flush look.
get 6 mm 9i/4"0 spacers so your offset then will be 46 mm. Probably OK with your 1.6" drop.
(weve found that many dropos don't match the advertised ones so measure yours: fender cnter point before and after drop on all 4 wheels.)
And the 205/40x17 tire is same diameter as stock pre09 but is heavier. Actually 195/40x17's will work better for mpg and acceleration; no penalty cornering by comparison. And no rubbing as we have one here so equipped on 45 mm offset. cheers.
Well i have a set of 17x7+45 and it doesnt rub with my drop, but i want the offset to be a little more flush so it will look a little more aggressive. I didnt know about the 195 tires doing that so i might get a 195 tire setting.
