Ebay lug nuts?
Ebay lug nuts?
I don't know if i should trust this, but i found forged aluminium lug nuts on ebay for less than 30$ for a set, i want to avoid the vision motorsports cause i've heard a lot of bad things about them, and most of there sellers are banned on forums unless someone can vouch for them...
The point is i don't want crap but i also can't afford high end like Kics otherwise i would have bought them immediatly... and the cheaper nuts look just like Blox but without the brand...
please if any of you guys used similar nuts i would like if you could share
Thanks!
Thanks!
Don't do it. Cheap ebay lugs are cheap. I've seen them get stripped out being threaded on the very first time. All it takes is a minor over torquing and the threads are gone. Just imagine a hard corner putting pressure on them...
Whats ur budget? Blox, Buddyclub, skunk2 can all be had for under $100. The ebay ones, depending on the ones your looking at, arent all bad. I actually run a set on my Beater fit. Have had them on for almost 2 years, taken off and put back on at least 7 times with no problems, and I drive that little beater HARD. I have the BLOX ones on my white fit and they also work really well, and I liked them because they were black chrome.
well i do wonder how they can possibly be that bad... most of the products are getting bad reputations because of bad users... i'm not saying that 15$ lug nuts on ebay are good, all i'm saying is that sometimes there is also a problem 18 inches in front of it too... XD
the only thing i don't like with muteki is that either come with a full set of spline drive or a regular set...
Honda and Acura Accessories dot com - Genuine Factory Honda and Acura Accessories at discount prices. have genuine honda factory wheel locks for 34$
Spring a little extra for the KICS, especially if they're steel. Those will last much longer than aluminum and are more resistant to thread loosening, although a little heavier.
I have Kyo-Ei's black steel nuts and Bull-Lock wheel locks on my car now and they're way stronger than my lightweight Work RS aluminum nuts. You could round off the edges of the aluminum ones if you're not careful with your hex nut wrench - it happened to me.
mmmh... well about the kics all i've seen so far are the ones @200$+ so maybe i still have some homeworks to do
rocketberger
19
11-13-2012 07:30 AM
Spyderfenix
18
12-22-2010 05:40 PM
