#7281
Thanks! I just used a high temperature spray paint from the local hardware/paint shop. Seems to hold up pretty good too. Just make sure you give it a good wipe down before spraying and do a lot of thin layers. You can't really see in this picture but the bottom right corner is a little blotchy because i sprayed it a little thicker than i should have lol
#7282
#7290
Not sure on offset, the name of the wheels is "R84 V-Spoke" if you wanna look it up. They are 16's. I was afraid they would be a little too wide but they ended up fitting perfectly.
#7292
Thanks, I might do something different to it cause everytime its sunny and I lift the hood I get blinded lol. I just used masking tape on the logo and taped it off really well. I tried to tuck the edge of the tape underneath the logo a bit so the paint could get as close to it as possible
#7294
FINALLY took my Fit in for the Master Window Switch recall released a couple years ago. They didn't jack up my trim too bad but there is a very small nick where he must have popped the cover. Nothing to fuss about.
Also had a coupon from Mahwah Honda for a free A/C system check. One of the things under the A/C checklist was clean condenser fins. Either they didn't do it at all or they only cleaned the ones that were free of debris already. *EDIT* On second look, I think they removed some surface debris that was stuck in the radiator. The crushed in fins are still the same way so it looked like nothing was removed.
I can't see how they would offer a FREE full cleaning of the rad anyway as its gotta be a couple hours of labor. Remove the bumper, crossmember, fans, hood latch, etc and drain the coolant, remove and clean the rad, refill with coolant and re-install everything.
Where's that DIY lower mesh grille thread? lol.
#7297
I got mines done a few weeks ago and I have a similar nick. They really should be more careful when handling these repairs.
#7298
Installed Music Link and replaced the rear seat foot guide. I also swapped the defrost and AC indicator lights so that I could better see when the AC is on. I also ordered new bulbs for those components as well as the AT gear indicator light. Sunday will see a new lower bumper and splash guard, tire rotation, oil change, transmission drain/fill, and checking the wheels for bad bearings. We should hit our 200k mark by the end of summer!!!
#7299
Got mine done last week. Dropped the car off with the trim already removed so it wouldn't get damaged again. Now I need to change the leds again lol
