Old 06-04-2014 | 06:44 AM
devmail's Avatar
Originally Posted by Rollerboots666
Where did you get your UR pulleys? What's the going price on those bad boys? Thanks!
I got them at www.SparktecMotorsports.com but you can also order them directly from UR but they did not have them listed on the website so you have to call. They are a little pricey but they are the lightest and will take 4.40 lbs off the drivetrain.
  #7102
Old 06-05-2014 | 01:17 AM
Previc93's Avatar
So last weekend I had a track event with nasaaz and the fit just wasn't ready so to have a good time I took the wife's car. Lol
Wish the fit was ready as I was 5 seconds slower than my fit. I won't leave her at home anymore.
  #7103
Old 06-07-2014 | 12:20 PM
EightyFour's Avatar
I noticed today my heat shield on the catalytic converter was rattling and when I went to check it out, one of the bolts had been rusted off. Since I had no brackets or anything so I took a piece of steel wire and wrapped it around the heat shield twice. No more rattle!
  #7104
Old 06-07-2014 | 03:24 PM
Dean's Avatar
Let's see.
In the past week I have:
  1. Changed Oil/Filter.
  2. Cleaned and re-oiled K&N filter.
  3. Bled the brakes.
  4. Changed Spark Plugs.
  5. Adjusted valve lash.
  6. Rotated tires.
  7. Changed serpentine belt.
  8. Installed new head cover gasket.
Good for another 100k, right?
Changing the serpentine belt is a serious pita. Never had to pull as much ancillary parts to get to one? Ended up pulling the airbox to get a straight shot to bolt on lower back 12mm bolt.
  #7105
Old 06-08-2014 | 08:05 PM
ikutoisahobo's Avatar
Nothing.
Haven't driven it for a month now...I need my Fit dose.
  #7106
Old 06-08-2014 | 08:35 PM
GinoLicious's Avatar
Installed some OEM keyless entry on my GD. Bought directly from Honda. Love my keyless entry.
  #7107
Old 06-09-2014 | 12:21 AM
Hootie's Avatar
Took it to another autocross event today. Didn't do too shabby time wise BUT now the AD08s are officially SPENT. Will likely replace them with Nitto NT01s.
  #7108
Old 06-09-2014 | 12:33 AM
Previc93's Avatar
Nto1 is a great tire!!!
  #7109
Old 06-09-2014 | 06:57 PM
p nut's Avatar
What I would like to do to my Fit today is install some OEM vent visors. Kicking myself for not picking up some when they were available through the dealer..
Edit: Found some OEM's on jdmgoodies.com. Should have them soon.
  #7110
Old 06-12-2014 | 02:35 AM
Rollerboots666's Avatar
With the mods you currently have the NT01 will knock you into SMF class. 140 treadwear is the min for STF and those Nitto's are 100. I see you're planning to go boost in 2015. The Nitto would do you well then since you will be in SMF. What class are you currently running?
  #7111
Old 06-12-2014 | 09:32 PM
Hootie's Avatar
Hey, I've been skimming through your BBP's thread. Its been coming along pretty nicely there.
I'm not running SCCA so the Nittos wouldn't really affect me per se... I run at a BMW club event in their X3F class just to get some seat time. X = Other make (non-BMW/MINI), 3 = 4 cylinder, F = Front wheel drive of course.
Over there in that classes are much more lenient so I'm completing against cars like DC2R and DC5S (equipped with ITR transmission and LSD), vehicles that are gutted, vertical and horizontal chassis bracing, cat-deletes, etc. Basically whatever front wheel drive SCCA class that DOESN'T have straight up slicks or better, runs X3. If they have slicks, they're bumped in to the "R" sub-class here for their vehicle.
We're currently on break until September due to the heat here so I'll be doing some mid-break maintenance, adjustments, and changes during this down time.
  #7112
Old 06-13-2014 | 12:10 PM
p nut's Avatar
Installed visors. Great fit. Except I messed up on the front driver's side. I tried to fix it, but ended up messing up the adhesive. Anyone know of a good way to fix it? It doesn't stay planted down (at the front, where I messed it up).
  #7113
Old 06-13-2014 | 01:52 PM
Texas Coyote's Avatar
I had to get some double stick tape for the visors I have in my GD-3.. I think I bought it at Lowe's or maybe Auto Zone.
  #7114
Old 06-13-2014 | 05:08 PM
p nut's Avatar
Yeah, I would do that, but it's just the very front of the visor that isn't sticking. If I could get a hold of the solution/glue that goes on the double sided tape, that would be best.
  #7115
Old 06-13-2014 | 07:10 PM
feifei's Avatar
Morimoto Mini D2S with Apollo Shroud retrofit done
  #7116
Old 06-13-2014 | 07:51 PM
That looks great! ^
Really clean!
  #7117
Old 06-13-2014 | 10:47 PM
What grill is that? It's different look to the Mugen or J's racing one.
So today I spent a solid $100 at Canadian tire. Purchased spark plugs, oil filter, and air filter. Air filter was installed, mine was so black. I may not buy Fram again we will see how this one is or if I'll just stick with OEM. plugs and oil change to be completed tomorrow when I return from the wreckers getting myself some honda pin connectors for a new project in my car. I also ended up buying a dremel and shaving out the inner ring of my bezel for my shift boot. I have a leather one and wanted the inner ring removed. Tomorrow in paint albersoft silver and buying real small screws to screw the boot in from the inside. Screws I have a .02 too long and don't want them poking through but I also do not want them lose.
  #7118
Old 06-13-2014 | 11:12 PM
feifei's Avatar
OEM sport grille painted body colour
  #7119
Old 06-14-2014 | 12:18 AM
I love the sport grille when it's color matched. It looks nasty in the satin finish.
  #7120
Old 06-15-2014 | 10:35 AM
p nut's Avatar
Ended up (carefully) taking it all off. Thankfully, the tape came off of the visor fairly easily. I went to Home Depot and picked up some Scotch/3M Extreme Mounting Tape ($6). It was 1" thick so had to trim it with a razor, but worked well.
