#6801
I think I need your job.
I started to clean my car today and found about 2 inches of water in my spare tire area. A leak that I knew of on the antenna and the cracks in the hatch area seem to have been the culprits.
Removed my headliner and am now in search of some new material for it. Put everything back together except for the headliner and a few panels.
#6802
My job is pretty stressful, I just save very well lol (well... if you don't count me dumping money into my car).
Just received a 10 pack refill for my air freshener. Squash!
It's the little things that make me happy.
#6807
^^ Those are good rotors!
I enjoyed my pair before installing these Carbotech AX6 pads... Initially ran Hawk's Performance Ceramic pads and they were a nice upgrade from stock when the pads had heat in them... Cold bite wasn't as good during highway stints though (likely due to my choice of pad with a slotted rotor) On the other hand... I'm not too sure about the Green Stuff pads though... I've seen occurrences of the braking material coming off the pad's metal backing plate. Not trying to scare you or anything but definitely keep an eye and ear out for that.
#6808
I also got these in the mail today, pretty excited to slap these on this weekend.
#6811
So you recommend the EBC rotors and Carbotech AX6 pads combo?
I currently have the Hawk+ in my car and they seem fine for daily driving. I had EBC's green stuff in my old car (Mazda) and they were nice as well but left a lot of brake dust, which is why I decided to get the Hawk+ for my Fit.
#6817
In the future I'm going to be upgrading my braking system.
I'm currently running Cryo-treated StopTech slotted rotors with the AX6s to combat this wear personally. Been running them maybe 2k miles with an autocross event included and no abnormal wear on the rotors yet.
#6818
I would not recommend running the Carbotech AX6 on EBC USR 850 rotors for something that is going to be used for daily use and/or with limited to no autocross time. The reason being, the AX6s will both wear their friction material on the pads AS WELL AS groove/eat away at the rotor (plus the ridiculous brake squeal/chirp). In addition to that, my AX6s put out a STUPID (to me) amount of brake dust after autocross days... And usually turn my flat light gray wheels almost gunmetal or bronze looking by the end of the day.
So I guess for my DD I don't really need slotted rotors or anything then right?
I def do want to get some ss brakelines and some high performance brake fluid. After grad school, maybe some Spoon calipers for bling. :shrug:
#6819
I just wanted to improve my stopping ability and have a more solid pedal feel.
I've had this happen before coming home from work after some idiot placed merge/lane closed signs of the blind side of a bridge (couldn't see it till after you crested the bridge) making a hella sketchy last minute merge. I was running the EBC USR 850s with Hawk's Performance Ceramic pads at the time and traffic had almost stopped at the crest of the bridge. An 18-wheeler was a good 4 or 5 truck lengths ahead of me suddenly locked up his brakes because of stopped/slow moving traffic. I had just started going up the bridge and braked hard as soon as I saw this. Didn't feel any brake feedback for a moment then finally began to stop after the pads built up some heat... ended up being maybe 5 to 8 feet front the rear bumper on that box trailer. Didn't feel ABS kick at all, I promptly ordered my AX6s the next day.
Anyway, that's my long winded opinion on why I wouldn't run slotted rotors on a daily driven car. If you do, make sure you have a pad with a friction material that features a GOOD COLD BITE otherwise you could be in a situation like I was in. Definitely put in some research before you buy.
Braided Stainless Steel brake lines are a good investment, I'm running some from Techna-Fit and how much firmer the brake pedal feels along with how much easier I can modulate during braking when autocrossing. When and if you do get BSS lines, make sure that if you install them yourself that you make sure you can go lock-to-lock and that there is no binding in the lines. My first pair of front lines from Techna-Fit would rub against my wheels during full lock turns due a design defect, I had to contact them and get new lines made to correct this... These new/updated lines should be in their catalog as well.
As for brake fluid, it wouldn't hurt to step up to say a DOT 4 fluid... but for mild, daily use (I.E. No autocross or road racing) DOT 3 is fine in my honest opinion. I personally am running Motul RBF600 which is a DOT 4 brake fluid.
#6820
Finally installed my Spoon B-pipe today! So I officially have a Spoon catback now! XD
Install was cakewalk but I wish that the pipe actually had 2 nuts welded to the rear flange were the axle back bolts up to. If I didn't have 2 nylon locking nuts and 2 washers I would of had to do a quick parts run. :/ In addition to that, the rear most hanger (its a 1 point instead of 2 point) on the pipe is a different than that of the factory pipe but still managed to use the factory rubber exhaust mounts to install everything.
Going to go for a drive later on today... ^.^
