#5101
Dropped the OEM lip kit and JDM spoiler off at the autobody shop today to get shot with SSM paint. Can't wait to pick them up tomorrow and get them put on! Base to Sport conversion almost complete.
#5102
Finally got to drive my SSM with the 15x7 RPF1's and 205/55/15 Dunlops on her, as soon as i got home i ordered Skunk2 springs and I have a set of KYB shocks in the garage. I'll post some pics once i get the springs installed.
#5104
Yeah i'm already rubbing, I went to the beach on Saturday with the new set up installed and was with my brother and i up front, and my fiance and 2 of her friends in the back. It was funny since all three of the girls in the back have been on diets for spring break/summer and have lost weight (and look pretty hot) and the car bottoms out...the look on their faces was priceless.
#5105
That is funny.. I was able to use some rubber matting used for flooring in horse stalls to cut circular shaped pieces to place over or under the back springs and on the top of the front spring to gain a little height.... You don't even need a spring compressor with the Swift springs... You might be able to find someone with a wheel well roller to work your fenders out wider. One or the other or some of both should do the trick ... I have 195-55-15s on my RPF1s and on rare occasions a tire would hit an inner wheel well liner clip.. I did OK using 205-50-16s on 16x6.5 45mm offset Kosei wheels with Swift springs... I'm on coil overs now because Swifts were too low in front for the roads here.
#5107
Man you had better get busy.. My engine compartment has way less in it right now than yours.... I'm waiting to see who the next K swap Fit owner with boost is going to be.... Even without boost you are sure to have a fun car to drive when you have it all together and sorted out..
#5112
On the brighter side of things, I did get the passenger front door and door panel done. Basically what I did was stick the weather stripping around the perimeter of were the door panel touches the door and the speaker's "plastic ring enclosure"...
...then stuck more stripping on the inside perimeter on the door panel.
#5113
great minds think alike. this morning at work i ordered a broadway mirror, short antenna (opposite of what you did, dont listen to the radio) and an exhaust
#5115
It clipped on fairly well, just have to give the door panel a few nice pops around the edges with the base of your palm to get the clips to all seat.
#5117
Dude how did you make the light turn off. i have my recaro seat in and i have been wanting to turn that dam light off for a long time now.
#5118
