Old 03-11-2012, 11:04 PM
T-Fit's Avatar
Originally Posted by eglass
Are the jdm heater controls the silver overlays around the knobs? How do they go on?
Yes, they are. You pull the knobs straight off (just a friction fit), i used a very small flat head screw driver tip to pry off the sticky ones that are on there now. Then just stick the new ones on and push the knobs back on. They have a small notch on the bottom to help you line them up. This only took me 5 minutes to figure out and finish.
  #4942
Old 03-11-2012, 11:44 PM
Lance's Avatar
Installed new wiper blades, a door panel clip, Rogue hood scoop.
  #4943
Old 03-12-2012, 03:03 PM
dled1286's Avatar
Ordered a Skunk2 Alpha header for my Si. Got something that didnt look quite right. Wound up the tuning shop i got it from intentionally sent me the more expensive (by far) and better quality (by far) Megapower header for the same price.
  #4944
Old 03-12-2012, 04:19 PM
MNfit's Avatar
what dint look right about the Alpha header?
  #4945
Old 03-12-2012, 04:25 PM
dled1286's Avatar
Its not the alpha lol! It had Meagpower written all over it. There are Alpha bagdes/stamps at different places along the runners and collectors like this:
and they were all missing. Instead it looks like this which is the megapower header:
I GOT UBER LUCKY!!!
  #4946
Old 03-12-2012, 09:07 PM
MNfit's Avatar
oh reread what you posted, that is badass!
  #4947
Old 03-12-2012, 11:47 PM
UmmFit's Avatar
Ripped out those back seats. The ninja's now nimbler.
  #4948
Old 03-13-2012, 11:52 AM
eglass's Avatar
yesterday i installed my ngk iridium spark plugs. seems to smooth the car out and make it a little more crisp. install really was not that bad, took maybe 30 minutes. it was time to replace them so i am really satisfied with the results.
and the tinted middle portion of my tail lights i did this morning. i still need to sand the clear coats and buff them but they look ok. you can also see the bottom part of the bumper that i sprayed with plastidip. let me know what you guys think!
  #4949
Old 03-13-2012, 07:03 PM
MNfit's Avatar
made some progress on the braket for my HR shifterbox. Hope I can get my bro to weld it up by this weekend
  #4950
Old 03-13-2012, 07:07 PM
Glockbag's Avatar
replaced front wheel bearings, and broke an abs speed sensor, and also installed extended front wheel studs.
  #4951
Old 03-13-2012, 09:02 PM
Funkster's Avatar
Hit 50k miles.
  #4952
Old 03-15-2012, 02:31 PM
eglass's Avatar
Finished install of my black headlights
  #4953
Old 03-15-2012, 02:59 PM
Rampo's Avatar
Just filled up the tank and computed 39.8 MPG. Fell within 0.2 MPG of dash readout. woohoo!
  #4954
Old 03-15-2012, 06:13 PM
ivanjm422's Avatar
This is what I did to the GD 2 days ago Rubbing on the fender liners just a tiny bit, I'll probably be taking them off or tucking them in soon. RPF1 15x7+41 on Kuhmo Solus 195/55
  #4955
Old 03-15-2012, 06:31 PM
dled1286's Avatar
Tuck the lining because that stuff doesnt withstand tire friction for ****. Mine rubbed my tires from about 3-4 days and wound up just gone. it just melts under the heat from friction.
  #4956
Old 03-15-2012, 06:42 PM
ivanjm422's Avatar
But what was gone? Just the areas that hit the tire? Haha I'm just gunna let it melt then I've noticed that because I'm rubbing much less than the first day I got them on!
  #4957
Old 03-15-2012, 06:50 PM
dled1286's Avatar
like half of the lining. It lost rigidity and more and more kept rubbing till half of it was gone
  #4958
Old 03-15-2012, 06:52 PM
mhmmmatthew's Avatar
If your signature is up to date I'm running the same specs. I trimmed my liner and zip tied it back so it doesn't rub.
Hopefully this helps.
  #4959
ivanjm422's Avatar
And no more rubbing after that?
  #4960
Old 03-15-2012, 06:58 PM
ivanjm422's Avatar
It is up to date What part did you trim away?
Quick Reply: What did you do to the GD Fit today?
