Old 03-05-2012, 01:59 PM
(AB)deal.'s Avatar
Added my personal vtec solenoid cover!
  #4902
Old 03-06-2012, 01:05 AM
Subie's Avatar
Over the weekend just replaced both headlight bulbs with Sylvania Xtra. Man, those Sylvania Ultras were bright but only lasted 5 mo. Let's see how long these Xtras last.
  #4903
Old 03-06-2012, 02:39 PM
vag0's Avatar
Changed the Tranny fluid and the 3rd clutch transmission fluid pressure switch
  #4904
Old 03-06-2012, 03:56 PM
tmkpres's Avatar
Originally Posted by DreaMv
i took off my rear wiper, Fit emblem and the Honda badge
Is that center piece a bought piece or is it the OEM shaved ? I hate the wiper,H and the bump where the H sits.
I'd like to replace it with just a flat piece like the pic above.
  #4905
Old 03-06-2012, 04:02 PM
JCrimson's Avatar
Originally Posted by MNfit
Its small but its something that has been bugging me for some time now. It cost me $10 and took about 5 minutes to do.
before
after
why was that there to begin with? an automatic thing?
  #4906
Old 03-06-2012, 10:58 PM
T-Fit's Avatar
-Put my rear wiper back to normal position
-drilled and mounted my tilt license plate bracket bracket
  #4907
Old 03-07-2012, 09:12 PM
MNfit's Avatar
When the shop did the swap instead of getting the bracket they just zip tied it to that location.
  #4908
Old 03-07-2012, 11:06 PM
T-Fit's Avatar
-490gram Blox Neo shift knob
-BWR license plate bolts and gold washers
  #4909
Old 03-08-2012, 02:11 AM
Texas Coyote's Avatar
I have had the Ultras in my headlights for 3 or 4 years and they are still lighting up the road... I put the next grade down from them in my wife's old pickup and one of then burned out awhile back... I believe I'm going to stick the new bumper and projector headlights on the car in a say or so.. I am also going to fix an exhaust leak between the header and down pipe which I'm going to wrap and coat with DEI silicone coating.. I'm also going to have to raise the car up a little higher front and rear so I don't destroy the fiberglass bumper.. If I am up to getting around as well as I did today I will knock out installing some other stuff I have .... All that I did today was clean up the area I work on the car in and put a new shift boot on the JDM console, put air in the tires.. I bumped them up to 41.5 PSI front and 38.5 PSI in the rear...My front tires had like 24PSI in them, I guess that's why they were making a lot of noise on fresh asphalt roads.
  #4910
Old 03-08-2012, 08:28 AM
dled1286's Avatar
Mine wasnt there either and i had an A/T. Thats roughly where it is on my FA5 but its supposed to be there.
  #4911
Old 03-08-2012, 08:51 PM
Guardianoffreedom's Avatar
i finished it
I had already shared the pictures in another thread but not here so hope you like
I replaced the stock headlights with these from a grey fit. Although im aware of the stock tow hook, I used to own an EG that had this style of tow hooks and thus I much rather have this one!
I replaced the stock fog lights with these yellow lens ones and relocated the license plate.
I was interested in purchasing the Advan wheels but the price tag forced me to go with the rota's version. No complaints, I actually love these wheels. I wish I would have gone with bigger tires but i guess these will do till the summer.
  #4912
Old 03-09-2012, 12:19 AM
T-Fit's Avatar
-Washed it
-Put my summer rims back on
Tomorrow:
-JDM heater controls
-vacuum interior
-pick up my new carpet floor mats
This weekend:
-Oil change
-put in my magnetic drain plug
-install Mugen strut tower bar
  #4913
Old 03-09-2012, 01:26 AM
raiderfit's Avatar
Haven't installed it yet but got a whole new audio system for it.
* JVC double din deck
* Sirius XM Unit
* 6.5 inch kickers co-ax for the front doors
* 6.5 inch kickers co-ax for the rear doors
* 12 inch sub
* Kenwood 5 channel amp to power up the 5 speakers
  #4914
Old 03-09-2012, 08:33 AM
dled1286's Avatar
Guardian, VERY clean...nice job!!!
Si i get home last night and powers totally out. I get depressed cuz no Top Gear to watch. But then wifey tells me "you have 2 big boxes in the other room"
...and this is what it was
Ordering my exhaust this afternoon...WINNING!!
  #4915
Old 03-09-2012, 01:27 PM
MNfit's Avatar
what header did you get?
  #4916
Old 03-09-2012, 02:05 PM
dled1286's Avatar
Skunk2 Alpha series
  #4917
Old 03-09-2012, 02:37 PM
MNfit's Avatar
Originally Posted by dled1286
Skunk2 Alpha series
make sure to match the flange of the header to the gasket, my brother has the same header and had to drill some of the holes bigger so the header would fit
  #4918
Old 03-09-2012, 02:48 PM
billboard's Avatar
took her snowboarding again...
  #4919
Old 03-09-2012, 03:06 PM
dled1286's Avatar
Ive heard of those problems. Hopefully it will be alright cuz from what ive heard is that and the infamous doughnut gasket le3ak is like a 50/50 chance. Im SOAKING my doughnut gasket in copper gasket sealant before hand tho
  #4920
Old 03-09-2012, 03:12 PM
ivanjm422's Avatar
I heard they did this on purpose so that the gasket would have a tight fit?
Quick Reply: What did you do to the GD Fit today?
