07 Fit MPG
#41
I noticed a lot of MPG threads and everyone is talking about 'x' miles to a tank...does anyone actually fill up till the pump turns off, drive 200 or whatever miles, fill up till pump turns off and write down that number and do the math? The difference of a fraction of an inch in the needles position could mean a good half gallon to gallon, drastically altering numbers.
I get anywhere from 20-25 mpg supercharged. Lower end being more city driving, higher end being more highway. Either way, MPG sucks. I used to get avg 26-27 doing 50/50 when I was NA.
#42
I wanna see how many MPG I get now with my tires around 45 PSI, the ride doesn't rattle me. I can't believe my dealer gave me the car with the tires just a little over 20 PSI I only got 27 MPG mainly city driving that way. I filled them up to mid 30's PSI and raised my MPG to 29, I just hope I get into the 30's now doing mainly city driving with 40 plus PSI and a freaking slushbox mounted to my drivetrain.
the tires that came with the Fit is recommended at 32 PSI!! you are lucky you did not have a blowout on the freeway...or else they would have had a HUGE lawsuit on their hands..
you should try keeping your tires at 42 PSI (cold) at first, drive around for about 20 minutes, and check them to make sure they didn't get too high while driving.
#43
No need to assume people don't know how to calculate MPG. I don't see any posts before yours warranting a condescending explanation like yours. Also, it's ALL about how many miles per tank, since that's the figure you'll be dividing with the # of gallons you put in afterwards.
Also, OP, you divide the your total # of miles by the gallons you put in AFTER driving that tank - not what you put in before. That 9.6 gallons isn't going to have any bearing on end results. If you mentioned it but know to use the actual gallons you put in after driving, then ignore me please.
300 miles to a tank is GREAT in my book. I used to get 250-270 per tank before modding the car, using a Scangauge and driving as efficiently as I could. If you're getting 33.3 MPG per tank, that's about where you should expect it I would think - you're not driving a hybrid after all.
ok, these Scangauge's you see in the back of Motortrend, Car and Driver, etc. is that what you are talking about?
they have gauges from HyperTech, DiabloSport and Superchips on page 141 of MotorTrend's May 2010 issue.
some say you can remap the transmission shift points, (which would be good for increasing fuel economy, having the car shift sooner at a lower RPM,) and you can also optimize the air/fuel ratio.
when i am on the expressway and going about 65 MPH, the tachometer shows my RPM's to be about 2600 RPM...that seems pretty high for doing only 65!
my 2003 Honda Civic going 60 MPH, would run at about 2000 RPM
is there anyway i can lower my RPM's while on the expressway??
#44
#45
I have stopped the high speed P&G + FAS on the interstate. The clutch work was too much for my 58 year old knee and messed with my 60min at 3.5mph walk-jogging every day. That cost me 10 to 15mpg on a 50mile dive easy. I still do it on my short rural drive.
My commute the last month is From Lake Worth to North Hollywood. About 45 miles. I found I can park it at 55mph on cruse no A/C and if the winds are not helping or hurting I get 45 mpg for that part of the commute. The wind can change the results +/-5mpg
Fit is still 100% stock less 60psi in the Dunlap P31's
#48
i got rid of those horrible Dunlop's that came with my Fit...i went and put on Goodyear Eagle GT's on my Fit Sport. handles so much better and it improves on the already amazing feel of the electric power steering.
the Honda Fit is the ONLY car with electric power steering that i have driven that doesn't feel like the steering wheel isn't connected to the front tires. other cars with EPS have very numb steering feel...Honda's are great when it comes to road feel through the steering.
the only drawback of the Eagle GT's are that my MPG has dropped about 3-4 MPG and increased road noise...
#50
#52
So i just purchased an 2008 GD Fit Sport with 30k on the clock.
Went up to Santa Monica Pier from San Diego and these are the numbers i got
I got to Santa Monica with an 1/8th of a tank over the half line, with cruise set at 70mph (right before vtec kicks in) and got 215 miles.
On the return it was late half way on the return i got bored with 70mph and went to 80 mph. And the efficiency significantly dropped
#53
That's a terrible loss in mpg's!!! I can't believe they have so much more friction.
#54
That reminds me how a silver CRV parks right beside my silver Fit in my garage. When I look at the 2 side by side, I can't help but think if my Fit became the equivalent of Kirstie Alley it would be that ungainly CRV In fact the pic below reminds me of my Fit parked beside the CRV. I'm sure you can tell which is which in it
#55
#56
damn...i only get about 250 miles on a full tank...but i live in south florida (Fort Lauderdale) and the air is on full blast ALL the time.
from December to February when it's in the mid 70's or so i don't run the air. then i was getting about 320 miles on a full tank.
about 60% city miles and 40% highway miles. at 65MPH, my RPM is around 2500, that seems a little bit high for a car with a 5 speed A/T..
i had a 2003 Honda Civic LX sedan and at 65mph, the RPM was around 2000.
i heard there are scanners you can buy to reprogram the transmissions shift points (shifts into higher gears earlier) and to reprogram the RPM to run lower at 65 MPH.
anyone ever heard of this?
#58
Update:
With 2 springs stiffening the gas pedal (sometimes my shins feel sore from the work it takes to keep the pedal down), and closely following the LOD gauge on my scangauge, I've been averaging 24 mpg all around. This is including the occasional boosted, WOT run.
I recently got my A/C fixed... and unfortunately my last tank was down to 22-23 due to leaving the a/c on 2 for a good duration of that tank. A/C really kills the mpg for me.
#59
First of all, I would like to say hello and I've been lurking on this site for a week or 2 before I registered.
Now I have a 07 Fit with 40k on the odometer. The car runs great but the fuel mileage concerns me. I inflated my tires to 50psi and dropped them down to 40 because the ride was alittle rough. I also put in some 0w20 mobil synthetic oil and a K&N filter.
All this has given me roughly 300 miles per tank. I also checked the spark plugs and they looked good. I ordered some ik22's anyway. I will install those when I recieve them.
In my research I have found that some Fit owners get good mpg and some dont. I hope I dont fall into the dont category but the way things are looking I'm already there.
Are there any other tricks or mods I can do to get my mpg better? Did I get a DUD Fit?
First, dtermining mpg by the number of milespwer tank, or fillup, doesn't have real measurements.
Instead, actually determine the umber of milesdrive from the last filklup and divide by the gallons you refilled.
Second, mpg on a Fit is highly dependent on the terrain you drive. You will get better mpg on flat level highways at 60 mph than at 70 mph or on hilly trerrain; likewise, the higher your speed and the more acceleration you do will cut back mpg significantly.
the tests we run hereshowpretty consistently 29 to 34 mpg; automatics are better on interstates thanks tohigher gearing, reaching 40 mpg; Manualshere get about 35 on interstates.
The shorter your trips, the more accelerating, as in traffic, and the maximum rpm you turn all take a toll on mpg. we have seen a Fit get in te low 20's during wionter, delivering papers.
