Maintenance Minder - Early Read
Old 12-11-2009 | 06:39 PM
SmartSizer's Avatar
Quick question:
Is there a a way to make the Maintenance Minder show the upcoming codes early?
For example - I'm at 20% oil life now. I want to change the oil, and reset the Mainenance Minder, but not miss the codes that might come up.
Thanks
Old 12-11-2009 | 08:21 PM
Koi's Avatar
Koi
Basically the way the MM works is that when you go through the MM reset procedure, it'll show you the codes for tasks you should do when you reach 5-15%, whatever the % is that the codes pop up. For example, let's say you have another 500 miles to go before the codes pop up - you can reset your MM right now, and it'll display the codes for what should be done had you waited till they popped up. When you go through the procedure it will display the codes for what should be done at the next time it reaches the % where the codes would normally appear.
Drewb
08-14-2015 08:58 PM
jlbryan027
14
06-30-2015 12:16 PM
The Fitness
03-08-2014 07:28 PM
mozarwasagenius
03-26-2009 10:09 AM
Antpwny
08-11-2008 11:45 PM
Quick Reply: Maintenance Minder - Early Read
