Piston slap anyone?
Old 12-01-2009 | 09:36 PM
willy65000's Avatar
Piston slap anyone?
I posted a thread a while back about this issue and I'd like to know if anyone else has noticed this. My car suffers from piston slap and I notice it if I start my car and idle it for a minute or two. After driving for a while and fully warming the engine it goes away.
Old 12-01-2009 | 09:50 PM
Texas Coyote's Avatar
I've heard piston slap in old worn out big bore air cooled motorcycles and VWs but not on anything water cooled except some ancient farm tractors....`Is your engine using an excessive amount of oil?.... I have noticed that my engine is making some unusual noises since the weather has gotten cool.. What I am hearing is coming from the intake inlet and goes away as the engine warms and the RPMs drop.
Old 12-01-2009 | 10:47 PM
willy65000's Avatar
The noise isn't coming from the top end like the sound that valves make on a cold honda engine. It's in the bottom end of the motor and is a deeper sound. Other than this noise it runs fine, gets good mileage and doesn't burn any oil to speak of.
Old 12-01-2009 | 11:05 PM
If you remove the top of your air cleaner box and remove the filter you can hear the sound get louder if it is what I am hearing..... It sounds mechanical and it might be from the throttle control valve on mine... Like yours it it will gradually quieten down and sounds fine when the cold engine light goes of and the idle RPM drops.... It sounds very much like piston slap.
Old 12-02-2009 | 02:36 AM
5speedwonder's Avatar
ford lightnings were infamous for severe piston slap in the first few production years
i haven't noticed any unusual noises at all on my fit 26k miles goin strong
Old 12-02-2009 | 03:34 AM
JDMxGE8's Avatar
I wonder if your piston rings seated properly.
Old 08-11-2011 | 01:46 PM
DOHCtor's Avatar
My engine is experiencing piston slap too, except i wont hear it when cold at 1200 - 1300rpm but will definitely hear it when hot at 850Rpm.... It sounds a lot like my old Neon! Except the Fit is 10 years younger and have a lot less milleage and was always serviced with AMSoil ou Red Line oils! I guess it will recieve the Wiseco treatement as it's out of warranty now...
Marko!!
Old 08-11-2011 | 02:28 PM
phenoyz's Avatar
DAMN I thought it was " Pistol Slap" ...my bad
Old 08-20-2011 | 04:54 AM
DOHCtor's Avatar
Boooeurns!!! :P
Marko!
ck42
01-04-2020 05:35 PM
Ryan2020
01-29-2013 12:03 PM
willy65000
11-19-2011 06:25 PM
Kwonye
07-12-2010 08:11 AM
Drewski
10-06-2008 03:08 AM
