Son installed under-dash LED, TPMS and fogs stop working
Hi Freak Friends!
I need help. My son installed LEDs under my dash, wired them into the interior fuse box. He had some problem along the way, but once he got them working, all seemed to be well. In a few days, my TPMS sensor went off and stayed lit. Around the same time, I noticed my fog lights weren't working.
He checked out the fuses for those 2 things and neither was blown, but he couldn't get either problem fixed. I think he tried to take the LED hookup out and see if that turned everything back on, but that didn't seem to work either.
OK, so I took my Fit over to the stealership today, since the oil needed changing anyway. Told them about the problems and they said it would be under warranty, that was *before* they spotted the LED lights.
After waiting until I had had 3 more birthdays .... (my GOD they are s-l-o-w) The service adviser told me that the problem is probably related to my LEDs....and that I will have to come back another day to have it fixed. Said the tech had narrowed it down to the fuse box inside (which is where son installed the LED fuse).
Long story even longer...What to do now? Can you not just install a piece of equipment in a blank fuse space? What if they try to charge me for labor or diagnosing since they will tell me it's the LED that caused the problem? Any advice on fixing it myself? How do you put in an LED if it's not hooked to the fuse box? I am at a disadvantage b/c I did not install the LED myself and I don't know if son did it right or did something he should not have. But I sure don't want to be ripped off - I have another shop I can go to if I'm gonna be charged for it anyway.
Hope you can help if you can figure out what i am asking!
I don't see an RO, the invoice # is HOCS510098. Bill Walker is the advisor. The record was in the wrong name, last name was Carter and that is not my name at all. I don't know if they have corrected it yet. They have it down as black and it's BBP.
Was the information for the car correct? anyways back to the topic at hand
Even tho there was an empty slot in the fuse box it may not be used cuz a certian accessory fuse goes there with some options. I'm not 100% on this, but that could be one reason
that is probably exactly what happened. I think I have to unhook the LED and take it back to your shop and let them re-set the computer so my TPMS light can go off and my lights can start working. Damn it I really like the lights but I don't know how to hook them up right...guess that can be a project for son when he comes back from A&M....
u should be able to tap into just about any source with led's tho they hardly have any draw at all usually...i know in my tib i tapped into my headlight power and put resistors in line so my boost, wideband, and egt gauges all lit up with my headlights and i had removed the lights from those and put in 3 led's in their places (total of 9, 3 per gauge)...
the only issue i could assume is that if he was under there and somehow grounded a power wire you may haev some issues but something with as small of a draw as led's shouldnt cause too much of an issue...
Because he's my kid and he's usually good with stuff like this. It's no major deal, really.
Oh, and I think he did use the accessory port, now that you mention it. He's an aerospace engineering student who also builds his own computers and does coding, so he's pretty good with mechanical stuff.
im not sure if the GD fit has them since it first came out in 2001 and i dont remember seeing it in the electrical manual, but i know most of the hondas lately have multiplex control systems built into the fuse box, so small things like aftermarket alarm installations, etc sometimes mess them up. i used to be a tech at an acura dealer and my friends 04 tl fried his fuse box with an aftermarket alarm, seen an rsx with all the weirdest things wrong, that seemed to have nothing to do with each other, and culprit was the fuse box..
not sure how your son wired up to the fuse, but cant he just remove the fuse and put the original fuse back where it was? did he use one of those add-a-circuit thingies?
did you check your tire pressure to make sure it wasnt a low pressure error lamp as it should work? 28psi is about when the TPMS triggers the light. with colder temps outside it could be that your tires are under inflated.
neil patrick harris
10-13-2011 11:45 AM
Juliane
10-22-2009 03:20 PM
B-Fit
07-19-2008 11:02 AM
