Problem starting the car! Help!
So the other day the car decided that it wouldn't start on the first try, but on the 3rd, 4th or 5th time. All day yesterday it did the same thing. But if you shut it off and restart, it'll start back up right away. Problem only occurs when the car sits. I don't think it is the battery or the starter because it sounds like its turning over strong. My friend and I think it might be the fuel system, but I want to know if anyone else had this problem. I really don't want to buy that $144 battery the dealer is pushing and it not be the problem. Has anyone else had this problem?
there are three things you need to start a car: fuel, spark, and air. you can troubleshoot the problem by going down the line
put your car into the ignition II position but don't start it. you should be able to hear some fuel spray. if you don't hear anything, the fuel delivery would be the obvious place to start. good luck!
my crx had the same problem you've mentioned. after new spark plugs, dizzy cap, plugs, and an overhauled starter it ended up being a bad ignition coil
my friend's nissan versa is doing this right now. it's turning but i won't start. it takes him about 2 or 3 tries for it to start up after the car has been sitting for a few hours. we figured out what was going on and we've concluded that it's the fuel pressure regulator. we're going to fix it this weekend.
gkitf16
07-01-2015 12:07 AM
