gas cap broken?
gas cap broken?
My gas cap seems to have broken today. When I try to tighten it, it doesn't put pressure, and it just keeps on clicking and doesn't stop or tighten up. Have any of you experienced this problem? Is the gas cap covered under the warranty?
I figure that this wouldn't affect the car except for the emissions?
long as your warranty did run out it should be covered if you want i can hook you up with my service adviser at spreen honda . dont know if your far from here . we are in loma linda ca.
Wait, wait... what you describe is normal. At first it should go a few turns and THEN it will just click, click,click while you continue to attempt to tighten... it's normal that way.
