GD progress rear sway bar question?
I see that the progress rear sway bar does not mount to the chassis with bushings. In the past when i have seen roll bars, they were.
does progresses rear sway bar work well with out mounting to the chassis?
I would say yes. I have not installed mine yet (waiting on coilovers to arrive), but based on the reviews in this thread it seems like everyone is more than pleased with how well it works... pretty much from post #91 on, LOL!
the reason it doesn't mount to the chassis with bushings is because the fit has a torsion beam rear suspension, which is most likely different from the suspension of cars you've seen equipped with rear sway bars. there is no need for the rear sway bar to mount to the chassis in cars with this type of suspension. however, it works based on the same principle, linking up the rear wheels to limit their independent suspension travel (thus reducing roll).
haha, to answer your question: yes it works well.
It doesn't have to mount to the chassis but it would be better if it did. When one wheel moves up and down compared to the opposite wheel the shape of the unmounted chassis bar distorts considerably compared to the controlled chassis mounted bars. Never tried on without chassis mounting and don't think we would.. That distotion just looks too uncertain to trust on track.
And yes with the Fit's tosion beam axle don't see as much effect from rear bars as changes to the front bar, such as complete removal.
the way our suspension in the rear works, it is basically just a swaybar. what the progress bar does is adds to what the stock suspension is doing.
and hell yes it does work
My concern is repeatability. A distortion rarely has repeatability and if you can't count on the suspension doing the same thing under the same circumstances there is a problem the driver has to sort out. Much like 'flexible flyer' chassis.
Then, of course, not having tried one, we don't know about the Progress bar. Its just a concern that can only be settled by laps around the race course. Laps repeatable? Lap time spread? etc.
AnlDyxp_GD3
21
08-14-2024 11:55 AM
steezo_
01-23-2018 05:34 PM
mkg673
12-03-2008 07:30 PM
ldweng
10-08-2007 03:41 AM
