can it be done - base to sport conversion
I have a salvage base automatic model fit. Wanting to bump up some features to the sport model. While I have searched, it doesn't seem like anyone has tried to buy the necessary parts to put OEM cruise into a base model.
Here is the parts list I think is needed (part numbers from bernardi)
36770-SLN-A01 - SWITCH ASSY., AUTO CRUISE SET - 53.03
77901-SLN-A00 - SUB-WIRE, CABLE REEL - 15.03
77901-SLN-A10 - SUB-WIRE, CABLE REEL - 15.03
- though I am unsure which subire I would need
My assumption is the wiring is the same on all cars and the ECU is the same, simply need to plug it in..... this is the case with my toyota pickup
That said, I think buying the paddle shifters for 37 bucks/each could potentially give you that feature as well:
78560-SLN-A81ZA
78565-SLN-A81ZA
I am also interested in simply installing the sport model Escutcheon console - part number: 54710-SLN-A62ZA for $37.03. This would allow me to get the JDM console with arm rest.
Anyone advise if this has been tried?
78560-SLN-A81ZA
78565-SLN-A81ZA
I'm not sure if adding just the paddles would enable the Base auto to function as the Sport auto would. I seem to recall the Sport auto tranny has a detent for the use of the paddles. The Base auto has P R N D, the Sport auto has P R N D S And while you can use the paddles in Drive you don't get the same function as you do in S. For this you may need a different transmission computer? Not real sure as I have the manual tranny.... You might call Bernardi Honda and ask them if the paddles would do what you think they will.
I am more concerned with the oem cruise upgrade. On my 08 toyota tundra, I simply bought the small stalk switch and a wiring harness. Plugged it in and it worked.
base and sports have different gauge clusters. For example, the front Fog light icon in the sport dash, is not present in the base dash. Another example, the sport fit dome lights fade on and off, while the base dome light is instant on/off. Why is that any concern? well, like many other things on the Fit, the controls are built into the gauge cluster. I would assume that for starters the base dash would not have the proper displays to show the manumatic mode of the sport auto tranny. And worst case, the paddle shift operations are somehow controlled, or at the very least processed through, the gauge cluster.
The car might be pre-wired for it, but I'd guess you need a sport gauge cluster and possibly a sport transmission ECU along with the parts you've listed to do a proper base-to-sport auto conversion. And those things aren't cheap.
That said, oem fogs are plug and play...
Further, the paddle shifters are the least of my concern. It doesn't magically make the car any faster or more enjoyable... I've driven this type of setup before. More interested in the cruise control and the Escutcheon to run the jdm console. At the very least, the sport escutcheon should be an easy swap.
That being said the OEM fogs are meant to be a bolt in and run conversion. But they don't work the way they do in the Sport, there isn't a stalk switch, and you don't get the icon on the dash. I'm also not sure if they will self cancel when you activate the high beams like they do on the Sport either. I'm not so sure about the CC. If your dealer offered it at purchase that means that Honda has a plug and run upgrade already available. As for the tranny, buy the paddles and see what happens, at worst you are out sixty some odd bucks. At bet you get the manual shift function for cheap!
Cruise Control shouldn't be a problem to install, but you could probably save alot of time and hassle by going with an aftermarket system that will work for sure. Most aftermarket CC systems can be bought and installed for under $200 and only takes a mechanic a couple hours to complete.
I'm thinking No on the paddleshifters. Even if the computers are the same you'll need more than just the actual paddles that go in the sterring column for them to work. I'm no expert on paddleshifters, but from what I've seen of them it's not something that'll be a simple "hook up two paddles and go" job.
I don't agree that it won't work, but I think the price tag would end up around 10 grand. Good luck with that... I'd put the aftermarket cruise control in (since the sport switches probably won't work without a sport ecu), get some lip kits and rims and call it a day.
350 miles on the odometer
edit:
and you know it won't work because you have tried it?
really, all I wanted was cruise control and possibly using the shifter cover off the sport model to allow me to use a JDM console. Not really a conversion
And I am into my car for under 8k bucks..... curious what you payed for your sport? Buying from the dealer, yes I would have bought a sport, but I had an opportunity to get a very low miles, very minimal work needed car
edit:
edit:
you'll need
r paddle -------------------78560-sln-a81za-------- 51.05
l paddle -------------------78565-sln-a81za--------- 51.05
cruise sw ------------------36770-sln-a01 -----------72.45
cable reel sub wire --------77901-sln-a10 -----------20.53
cable reel ------------------77900-sln-a11---------- 193.60
instrument harness -------32117-sln-a30 -----------770.05
meter (guage cluster)---- 78120-sln-a21 -----------463.65
this is to just have the paddle shifters and appropriate hire harnesses to controle them, then you'd need the ecu that has the capibilities for you to control the shifters
ecu -----------------------37820-rme a71 -----------498.67
the cluster is because you changed the dash harness because you changed the cable reel... and so on and so on.
after all that i hope the other wire harhesses plug into the stuff you changed out, hey more power to you if you want to figure this out, and cut corners to make it work, but then it is JUST TIME AND MONEY
I agree do a JDM conversion and embrace the base you have - i have a sport but i love alot of the stuff that the base has (the ft bumper w/o fogs, the rear bumper w/o holes drilled for the rear lip) but i do love my cruise, keyless, extra speakers, and wattage of the radio, i love my paddles - mostly for downshifting ----> I JUST LOVE MY FIT!!!
I don't know if you can really just swap in a "shift cover" that has a different amount of travel and a different number of positions. I once owned a base AT Fit and hated that I couldn't get the jdm console for it, now I have a sport AT (base was totaled) and I have decided the aftermarket arm rest from zeta is plenty good enough for me. 250 bucks versus 50 just isn't worth it for me.
![Rolling on the Floor](https://www.fitfreak.net/forums/images/smilies/rotfl.gif)
![Roll Eyes (Sarcastic)](https://www.fitfreak.net/forums/images/smilies/rolleyes.gif)
![Big Grin](https://www.fitfreak.net/forums/images/smilies/biggrin.gif)
WELL LET ME START off by saying that it all becomes a giant ROLLING BALL OF PARTS , and doesn't include labor so let me show you why this wont work
you'll need
you'll need
I do care about cruise control.
Well i'm not tryin to start a fight i'm just sayin that it's alot harder than it seems, i have people call me atleast once a day that want just one option off the next higher model than they bought, and nowadays honda is so specific to each model that you can't do that anymore - sorry
but if you want cruise try a search cause ther are several people that have AM cruise and it's a slick install and doesn't require a bunch of wire harnesses that honda would require
