Are these standard windshield wipers
Regular replacements will work, they just look a little odd since most generics mount on the top of the arm, where the OEMs mount kinda on the side of it. I replaced mine with generics and they work just fine.
Look on-line. One of FF's sponsors sells them. BernardiParts.com , I think!
OEMs are not that expensive.
Note that the front blade set is, indeed, a set. You get both right and left blades and inserts at that price. Ditto the insert set. You get both left and right inserts. Unless your blades are physically damaged, there's no need to replace them. Just get the inserts. BTW, if anyone is interested in the rear bumper applique, Bernardi still has them for only $25. You can't beat that with a stick.
Warning about RainX replacement blades:
Before my '07 Fit got wrecked, I replaced the stock blades with RainX, from a SPAM ad. The blades worked fine, and I also got the RainX glass treatment with the blades. The only slight problem was that the passenger side blade was 1/4" too long. At rest, the wiper actually sat on top of the black plastic scallop piece at the right bottom corner of the windshield. The RainX wipers actually worked great except for the dimension flaw.
My experience with aftermarket wiper blades
I recently replaced my blades with Anco Winter blades.
Why?
I decided the path of least resistance was to pick up a couple blades from the local auto parts shop and see how they perform. Note that most windshield wiper manufacturers consider the correct sizes to be 24" for the driver's side and 16" for the passenger's side.
The 16" Anco blade is too long for the passenger's side. The Fit's OEM blades are exactly as long as the inserts. Aftermarket blades frequently protrude past the insert on both ends by up to 1/4". This will scrape along the weird plastic cutout on the passenger's side. I wound up buying a 15" blade for the passenger's side after doing some measuring and visual comparison.
Pros: They work great so far, with none of the chattering my OEM blades were doing.
Cons: Since the 15" blade is slightly smaller than the OEM blade, the uncleared area on the windshield between the blades (on the passenger side) is a bit larger. If your passengers are going to complain about a few extra inches of crud left in their field of vision, get the OEM blades. Otherwise, most aftermarket 15" blades seem to be fine for passenger side use.
Why?
- My driver's side OEM blade was damaged
- My local Honda dealer is a disgrace, they never have parts in, and I couldn't wait for replacements via mail order
- I'm not driving 20 miles to the next nearest Honda dealer for wiper blades
With the trico or RainX, the reference will give you one that goes to the edge of the windshield, which is correct except for the plastic overlay. On the 08 Fit, I took a scissors and cut from the end of the pass blade inward at an angle. So it meets the windshield just inside the plastic piece, but the metal part of the blade hangs over the plastic by about 1/4-1/2" and that's fine. It doesn't seem to rub.
Exact Fit® - Replacement windshield wiper blades for nearly all vehicles | Trico Products
I've had great experience with and highly recommend the trico winters for...yes, winter.
Any old wiper brand should work as long as it's compatible with the hook-type connector on the wiper arms.
I've used Bosch and NWB/Denso wipers, both are pretty good in hot weather. A set works out to about US$12-15 in your money for the 20"/15" length set, which will work fine
A friend of mine tried the 22"/16" combination for the front wipers and found they wiped a lot slower.
eh, i can live wit a 1/4 hangin out i guess, or ill cut it off or sand it curved lol -chrugs- ill manage. although my REAL ocmplaint is the rear window, idk if this happens for you guys, but on wet roads, EVEN barely wet roads, or just a damn puddle, the mist flys up and stays on the rear window, unless i turn on the wiper, which smears it and i even use the RAIN-X window washer fluid on the rear window, still dirty -.- so i looked on the rain-x website for thier blades (they dont have 15" blades -shrugs-) and it says that for the rear wiper: "Rain-X Wiper blades are not available for this model at this length. Requires OEM replacement part. Contact your vehicle manufacturer" Im assuming the OEM length of the blade is less than 16", i guess thats why ill be needing "OEM replacement part", question is, what friggin OEM replacement part!??!!? much thanks in advance :]
195 to 243 with one +REP.
Do iKONA's wiper delete and don't worry 'bout it!
(Psst...USE Aquapel on front AND rear glass!)
i googled "ikona wiper delete" and i coudnt find exactly find out what it was, one of the results tracked back to fitfreak.net, but was invalid -shugs- hell if i kno lol can u link me? went to the aquapel site and, no wipers? huh? im lost lol are you saying i should spray it? :P
I replaced the wipers on my wife's Fit a little while ago. The recommended size for passenger side is a little too long, so I cut it about 1/4" and it works perfectly.
I want to get the Spoon Sports wiper blades on my Fit, but I find it hard to justify spending $90 on wipers
Take a look at the links in my post, above. They go to the pages for the blades and inserts for both front and rear.
Rain-X® Wiper Blade Selector Guide
thing is, i want rain-x wiper blades, for some reason i just belive in thier rain-reistance quality [except the hand-applicator products, BLEH] but at thier site, it states it needs an OEM replacement part. i dont know that part they are talking about, is it the metal/plastic part? or is it something that goes on the "pivot piece" -shrugs- and this is only for the rear wiper, the front wipers do not need replacement parts. Here is the link im talking about, look on the bottom in green text.
Reading the text, I don't understand your confusion:(emphasis added)]
Originally Posted by Rain-X Website
Rain-X Wiper blades are not available for this model at this length. Requires OEM replacement part. Contact your vehicle manufacturer.
Properly applied, I've never had a problem with using regular old Rain-x on my windows. At 8 months and 18,000+ miles, I haven't had to add any windshield washer fluid, either.
