2007 honda fit sport p0302 misfire #2
Old 03-02-2022 | 10:32 PM
pdamianidis's Avatar
Smile 2007 honda fit sport p0302 misfire #2
Hi,
I could use some help please. My problem started with the P302 cylinder misfire. I limped home 11 miles. While running my engine at home to trouble shoot, performance deteriorated significantly to the point where now the engine cranks but does not start. I also believe my catalytic converter might have been damaged because I ran the engine with a cyl 2 misfire and thought that this might be causing the CRANK BUT NO START condition. I changed my plugs and coils 20K miles ago but changed them again because the coils came apart when I tried to remove them (aftermarket) to check them and the plugs. I used Hitachi coils and NGK plugs this time. All plugs looked healthy, no oil etc. I checked spark, & it was Okay. I performed valve lash adjustment (some valves were out of spec). Fuel pump energizes and I have fuel at the quick disconnect fitting which leads to fuel rail. I did not test actual fuel pressure however as I do not have the Honda adapter and gauge set up. I sprayed starter fluid in the intake to see what would happen and vehicle started as long as I maintained the spray. So, I’m a little confused now and not sure what to do next. Thank you for any help in advance!
Old 03-04-2022 | 09:58 AM
doctor J's Avatar
Does the fuel pump makes audible noise for 2 seconds when you turning your key to start?
have you inspect fuel pump connector (under metal cover, as it seems to melt on some cars).
Old 03-04-2022 | 06:43 PM
Yes. Pump is on for 2 seconds and I can hear it for about a second or two after ignition is off. I do have some fuel at the fuel pressure test site behind the fire wall. I am suspecting I have some restriction in my fuel line and more than likely it is my fuel filter (in my pump!) Is this a replaceable part? Oh, and I know about the fuel pump connectors, this is my second pump
Old 03-04-2022 | 10:12 PM
dwtaylorpdx's Avatar
Bad ground is the devil in hiding..
Missfire
02-01-2020 02:53 PM
birdman2447
03-20-2018 03:09 PM
auralee
12-19-2017 04:13 PM
meows
07-04-2016 10:25 AM
gfrobe
07-25-2015 10:08 AM
Quick Reply: 2007 honda fit sport p0302 misfire #2
