Pesky p0457 (check fuel cap)
Old 06-10-2021 | 08:02 PM
MTLian's Avatar
Hello,
2007 GD3, manual transmission. No mods except HFP muffler.
so my scan gauge is bringing up p0457 evap leak (pending code) and my dashboard is showing check fuel cap. Got the message on the highway so I took an exit, pulled over and tightened the cap. Still the code. Stopped the car, cleared the code, tightened the cap and went on my merry way. Code and dash warning came back on while driving on the highway. Tried tightening and restarting today (24h later) and still same. Idling a little rough too.
I don't see any obvious loose airbox hoses but I checked my air filter and it is pretty dirty (yes yes, I will change it ASAP). Could it be a dirty air filter is the culprit? My gas cap gasket looks nice and clean and the fuel line opening is clear of debris.
Any suggestions?
Old 06-13-2021 | 11:39 AM
doctor J's Avatar
substitute gas cap and recheck
Gas cap has a vacuum valve (can be stuck open) and filler neck seal which either cracks or hardens allowing leaks. Most smog shops checking the gas cap but this "checking" cost more than a new or used cap
payluder
06-28-2016 01:06 PM
ztyhurst
07-08-2012 09:06 AM
SkEEzY_GT
07-22-2010 02:56 PM
Daniel1975
09-21-2006 12:12 PM
jack_90125
05-27-2006 01:00 AM
Quick Reply: Pesky p0457 (check fuel cap)
