Airbag Replacement Advice
Hey Fitters,
I need some advice. I have a 2008 Fit and the passenger side curtain airbag and seat airbag deployed when I hit a curb. The dealership wants around $4,500 to replace the two airbags, headliner, SRS module, and the seatbelt lap tensioner.
I can save some money by having Safety Restore (dot com) fix the outer lap belt tensioner and reset the SRS module. I can also save little bit more by buying a used (but un-deployed) seat airbag.
If I go this route, I'm trying to figure out the correct order to do them in. For example, if I send the SRS module off for a reset, can I still drive the car to the dealership without the module and then have them install it after all the other components are replaced, so that new codes are not stored back on the module unit.
Obviously the airbags wouldn't work without the SRS module installed, but they won't work currently anyways.
All-in-all this would cut the price roughly in half.
Any insight is much appreciated!
Thanks!
Jax
Thanks!
Jax
For anyone curious, I ended up doing it all myself.
Here's a rundown:
Right seat airbag from eBay — $70
Right roof airbag from eBay — $85
Airbag module reset from SafetyRestore.com — $50
Right seat belt and pretensioner repair from SafetyRestore.com — $100
ZR13 OBD2 Code Reader from Harbor Freight — $190
Anyways, $500 is a lot better than $4,500 from the dealership. Just takes a little time and patience.
NOTE: The headliner was in good shape structurally. It just has a really minor crease in it so I'm keeping as-is for now. New headliner runs about $450 fyi.
Jax
Here's a rundown:
Jax
Here's a rundown:
Jax
Here's a rundown:
Jax
bhacker1994
04-20-2016 12:25 AM
lovelyfit
03-03-2009 12:34 AM
