A/C Issue (Honda Fit 2008)
Old 08-20-2019 | 03:54 PM
one.minjae's Avatar
My A/C stops working in 15 minutes. then an hour later it starts working again and It works every time in the morning. i thought the a/c was low on refrigerant so I had it filled up since it was running low. but it did not fix the problem at all. a/c lights is on but the a/c comes on and off everytime and I am planning on going on a long road trip so, please help!
Thank you.
Old 09-18-2019 | 06:13 PM
Safehandle's Avatar
Thank you.
When the ac stops working check to see if the compressor clutch is still engaged or not. I had a similar problem and it was because my compressor clutch coil was going out. Eventually my ac stopped working all together. I replaced the whole compressor and its been working perfectly for the last 2 months.
rw02kr43
10-12-2019 09:00 PM
BigArbys
11-14-2014 07:49 PM
pr1970
12-14-2013 06:43 PM
Kozway
05-03-2012 10:17 AM
Cat
10-03-2007 06:29 PM
Quick Reply: A/C Issue (Honda Fit 2008)
