Honda Fit feels very loose in the rear
Old 06-11-2019 | 02:00 PM
Safehandle's Avatar
I have a 07 base model and when I turn the wheel back and forth it feels like the rear end is swaying around and loose. I checked my tire pressure and it seems good, I also recently got an alignment. The car has almost 180,000 miles and I’m wondering if maybe my shocks are blown? Or maybe something is loose in the rear torsion beam? I’m not too familiar with the Honda Fit suspension but any input is appreciated
Old 06-14-2019 | 09:43 AM
Alco RS-1's Avatar
If they are original, your rear shocks are most certainly worn out after 12 Years and 180K Miles. You should replace your front shocks/struts too. A shop would likely recommend new tie rod ends and bushings too. Aged rubber suspension parts will be worn, cracked, hardened, etc.
Notsofitmike
3rd Generation GK Specific Suspension & Brakes Sub-Forum
11-19-2019 04:18 PM
mrphilip
05-17-2017 08:55 PM
ralphch
01-07-2017 11:10 PM
fit2bking
04-29-2015 06:37 PM
Skimmer
02-08-2008 05:50 PM
Quick Reply: Honda Fit feels very loose in the rear
